I removed the tank to look into my tank vacuum issue. Don't do what I did and think that that rear tank bolt is a hinge. It is a hinge for a few inches, then it acts like a lever on the metal bracket, and bends it.
Luckily, it can be bent back. But that is a PITA.
Triumph at the factory also torqued the plastic trim bolt on one side so much that it dug into the plastic, revealing white
Under the tank is four fittings. Fuel (doh), electrical (so your tank can explode like an airplane over long island), and two little nozzles that join two little hoses. One hose has a plastic fitment a few inches down, and goes "somewhere", the other one goes straight to the ground.
I didn't find any crimps that would explain the sucking sound at every gas station.
But i also didn't see, (before it was too late), which of the two identical hose tops went onto which of the two identical and unmarked nozzles!
Does it matter? what does the longer hose that goes somewhere actually do?
I blew into the ground hose, and it was clear. How does the air get into the tank to replace the fuel that comes out, via the straight-to-ground hose?
