ShopTriumph.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comTrident-Exhausts.comSpringfield ArmoryBikeBanditRacerPartsWholesale
Old 10-03-2005   #1 (permalink)
revolve99
Went to the mechanics this weekend and the mechanic notice some ticking noises coming from the engine.
He told me that I needed to replace the gaskets on my header and that if I don't replace them that they would damage my valves in some way.
Will replacing the gasket solve this problem?
Thanks for you help.
Old 10-03-2005   #2 (permalink)
Favorite Bike: '04 Speed Triple
Other Motorcycle: '02 Honda crf450r
Possibly tightening the bolts on the headers might help. They do tend to loosen and should be checked every so often. Unless the headers have been removed previously or are going to be removed, there is really no reason for the gaskets to be replaced.
Also, what kind of ticking noise is it?? These engines do tend to tick and it could just be the fuel injection. But that is just my .000000000002 cents.
If you trust your mechanic then maybe replacing the gaskets is what you need to do. If your not sure, get a second opinion.
"Nekkid Aggression rules"
ken750f is offline   Reply With Quote
Old 10-03-2005   #3 (permalink)
When did you do your last oil change?
Old 10-03-2005   #4 (permalink)
If you have never done a valve job on it, you could be hearing the valves ticking. It's an 01, so it is likely time.
DwarF is offline   Reply With Quote
Ticking noise? bcade Speed Triple Forum 19 04-05-2007 12:24 AM
ticking/clicking engine noise Slick The Rocket Science Forum 9 10-05-2005 12:27 PM
clicking/ticking engine noise Slick The Rocket Science Forum 2 10-03-2005 10:34 AM
ticking noise hinkleyboy Triumph SuperSports 5 09-10-2005 02:56 PM
Ticking Noise areg Club Cafe 10 06-29-2005 12:28 PM
