Sunline Shifter Mod - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 07-06-2011, 05:37 PM   #1 (permalink)
Main Motorcycle: My 09 Speed Triple
Tire Torcher's Avatar
Other Motorcycle: 2003 FZ1
Sunline Shifter Mod
Well I have had some time to put a few miles on this shifter mod now and have to say; Why did Triumph not do this from the factory? What a difference. No exaggeration, I have not had a missed shift since I put this shifter on. Even the odd time where I have been a bit of a ***** with the shift action, it slips right in. 1-2nd, 5-6th makes no difference absolutely positive action. I can't remember who it was that came up with this mod, but thank you thank you thank you! I highly recommend it to anyone who has had the slightest issue with missed shifts. Biggest bang for the buck ($28.00) upgrade so far.
More cowbell!
Tire Torcher is offline   Reply With Quote
Old 07-06-2011, 09:51 PM   #2 (permalink)
Main Motorcycle: 03 speed triple
never heard of it? Do you have link?
bedaring08 is offline   Reply With Quote
Old 07-06-2011, 10:03 PM   #3 (permalink)
Main Motorcycle: 2010 Speed Triple
Goop's Avatar
Other Motorcycle: '08 FZ6 - sold
Love mine too! Shifts very solid and never had a mis-shift after installing it.
Goop is offline   Reply With Quote
Old 07-06-2011, 10:04 PM   #4 (permalink)
Goop's Avatar
Check out this thread:
http://www.triumphrat.net/speed-trip...08-1050-a.html
Old 07-06-2011, 10:25 PM   #5 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
I am an early adopter but not the originator .
The first mention was in this thread Post #6 mcfetherolf.
DieselGeek is online now   Reply With Quote
Old 07-07-2011, 01:06 AM   #6 (permalink)
Main Motorcycle: 2007 Speed Triple
Other Motorcycle: 1999 VFR800--retired
I too have done this mod. I think it is worthwhile but it does not come without compromise. The sunline is not made for the S3. The peg breaks away in the wrong direction, so in the event of a low side your screwed! It will rip off your transmission shaft! I think this is why the Triumph engineers designed the multi linkage setup...it will prevent the input shaft from being harmed in an accident. Also, the design limits any lateral forces on the shaft. I track my S3 often, so I'm probably going back to the 'safer' factory setup. After all, if you spent over $200 on sliders to prevent damage, would you keep a shifter that might $everly mess up your tranny if you low side?
Will
lospice1 is offline   Reply With Quote
Old 07-07-2011, 01:23 AM   #7 (permalink)
Scary thought, I'd be interested to hear from someone who has done this mod and then dumped on the shifter side. I have dumped a lot of dirt bikes long before folding levers and never seen a broken shaft, but I suppose it's possible. I would hope the aluminum would just bend before the hardened shaft would break, especially with the drastic outward reach of the Sunline shifter.
More cowbell!
Old 07-07-2011, 03:05 AM   #8 (permalink)
Main Motorcycle: Whatever I'm riding
jon6.0's Avatar
I also think the aluminum would bend way before a steel shifter shaft would break. I've also gotten the false neutral 5th-6th a few times now even with the new Sunline shifter. Of course I wasn't shifting like a boss when that happened. I just changed my oil to Castrol 20-50 fully synthetic motorcycle racing oil from the Triumph Mobil One. I'm looking forward to see if I can notice any difference with the oil change.
09 White Speed Triple, Racetech Gold Valves front and back set up for dirt/gravel/touring on rough roads, SW Motech dirt/street pegs and Alu-rack, Sunline YZ85 shifter, Rox 2" risers, Scorpion Trail tires.
I don't need no dang "adventure" bike.
jon6.0 is offline   Reply With Quote
Old 07-07-2011, 03:39 AM   #9 (permalink)
Main Motorcycle: Tiger 955i 2006
Other Motorcycle: Matchless,Montesa,Xl 500,
Extra Motorcycle: DR600 , 850 LeMans MK111
Will
Thats what I was thinking. The standard set up is also infinitely adjustable.
QUOTE=lospice1;1945057] I have no idea why Triumph did not design and implement the shifter in this way. Seems to me a direct linkage is better than ball joints.
I think it is ( the original setup ) to minimise on leverage on the selector shaft itself, by putting the one piece lever on it, it increases the " side push " on the slector shaft .The old 955 Tiger had a long selector shaft that was supported outside of the gearbox by a plate with a hole in it before the one piece selector lever.Is the replacement lever that you are using designed to be fitted backwards, just thinking about the way the ends are meant to fold backwards if they come into contact with anything ?
chopped knuckles is offline   Reply With Quote
Old 07-13-2011, 09:35 AM   #10 (permalink)
Main Motorcycle: 2005 Triumph S3 1050
Other Motorcycle: '67 T120
I took the advice and just installed it last night! 100% improvement in shift feel and quality!!
Not only am I NOT drunk, but this tape DOESN'T taste ANYTHING like scotch.....
http://www.facebook.com/home.php?sk=...p?id=738205396
DirtDigglerS3 is offline   Reply With Quote
Shifter Help swassermann Triumph SuperSports 2 06-02-2011 09:54 PM
02 Shifter? notinme Twins Technical Talk 1 08-16-2008 06:48 PM
air shifter crogger T3 Sport / Touring Forum 4 02-17-2007 11:33 AM
Gp shifter or reverse shifter for t595 or 955i a82383 Daytona Deliberations 6 05-09-2006 12:24 PM
Shifter GrayRocketIII The Rocket Science Forum 3 09-27-2005 06:11 PM
