At last some credible dyno data - thank you Legman. There is some difference between Staintune's claimed +9hp peak gain and the graph data so I took a shot at correcting the data to the standard hp rating at sea level at std atmospheric conditions.
A Google search turned up a conversion site thats worth a look :
http://www.csgnetwork.com/relhumhpcalc.html The dyno data shows the runs were done a couple of days apart at approx the same time of day so if we make a few guestimates at the local conditions we can plug them into the converter and come up with a ball park estimate of the delta HP at standard sealevel. The converter site gives explanation in greater detail of the std/base input data.
Temp 87F, Sea Level Air Pressure 29.235 in Hg, Rel Hum 60%, Altitude 2073ft (632m) - Google - Mittagong NSW
Out pops a Correction Factor of 1.142 to be applied to the raw dyno data and 1.142 x 7.6delta HP = 8.7HP @ sea level and standard atmospherics. Allowing for a little inaccuracy in the input estimates I'd say +9hp @ sea level std is a fair call from Staintune. I have absolutely NO connection with this company or any interest in this business except fact finding.
I have no idea if this factor can be applied to the torque figures.
Cheers guys
