Here is that GSXR M/C on my TL - I have the same one on my Triumph, just this image is clearer than anything I have for the Daytona.
Radial master has the piston/cylinder perpendicular to the bar, whereas the conventional M/C is parallel to the bar.
Note that you will need new lever for it also.
And ideally get the res bracket from the later S3 Part #
T2021004
