Have you considered a Barracuda? I picked one up for $245 plus shipping from SMF Cycles. It's a mellow-sounding pipe, and the fit and finish is VERY good. Also, it comes with a removable baffle which is very handy for those longer rides when you need it to be a bit quieter.
Also, have you considered the Triumph off road pipe? The GREAT thing about the TOR is that the dealer can install the factory designed fuel map for you - and many do it free of charge when you buy the pipe. If you go with an aftermarket brand, you'll either need a Tuneboy or Power Commander in order to create an optimal fuel map. Without some fuel map modifications, you'll likely get some backfiring, too.
I am running the Barracuda with the stock map now, but I KNOW I could get even better sound/performance with some fuel map tweakings.
Check my photo album for pics of the pipe installed.
Dan
[ This message was edited by: 97TB on 2005-09-23 08:15 ]
