Overtightening the plug could deform the O-ring, causing it to lose it's seal. You could try some Teflon sealing tape on the threads, just be careful not to let any drop down into the case the next time you remove the plug. If the problem persists, it might be worth investing in a new fill plug or at least a new O-ring, as it's difficult to tell when an O-ring is worn out. Just my thoughts, but I'm no expert. Good luck!
Ride it like you rented it!!
