The octane rating depends on compression, the higher the octane the more compression it can take.
If you put 89 in a vehicle the requires 93 it will pre-ignite because it cannot handle the compression.
in other words the... TOR's and new map will not change the compression your safe with 89 or higher.
....now if you get pinging or knocking in the top end, thats pre-ignition - up your octane.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
