ShopTriumph.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comTrident-Exhausts.comSpringfield ArmoryBikeBanditRacerPartsWholesale
Old 09-21-2005   #1 (permalink)
div2's Avatar
The PO of my 1996 S3 changed the oil without replacing the sealing washer, so of course it's dripping a few drops per day. I want to install a new sealing washer and I understand the OEM Triumph part size is 22mm ODX14mm IDX2 mm width. I don't have time to make a 200mile round trip to the nearest dealer, so my question is, are the OD and width dimensions critical, or will any 14mm ID copper seal ring fit? The oil is only @200 miles and about one month old, so I plan to reuse the oil and not change the filter. Thanks!
div2 is offline   Reply With Quote
Old 09-21-2005   #2 (permalink)
Not sure how critical the dimensions are on that part. Have you thought about having the dealer mail you an OEM replacement since it's such a long haul for you?
Ride it like you rented it!!
cshell is offline   Reply With Quote
Old 09-21-2005   #3 (permalink)
div2's Avatar
Well, that's the plan if I can't verify that a regular 14mm seal washer will work.
Old 09-21-2005   #4 (permalink)
Favorite Bike: '01 Speed Triple
When you drain your oil, take the washer to NAPA and match it. That's what I did, and it hasn't leaked.
Speed3 is offline   Reply With Quote
Old 09-21-2005   #5 (permalink)
div2's Avatar
Sorry, what I meant to say was the PO didn't use any seal washer at all, so I don't have anything to match up.
Old 09-21-2005   #6 (permalink)
Favorite Bike: coming soon
geezerx's Avatar
Other Motorcycle: '04 VFR
Extra Motorcycle: '96 R1100RT
the dimensions you posted in the original thread match the dimensions of the crush-washer currently being sold by my triumph dealer. however, i can't confirm that they are correct for your '96.
2mm is a good ball park figure for thickness of the crush-washer. the id of the crush-washer should be "just" large enough to slide over the drain-plug threads. the od of the crush-washer should be slightly larger than the width of the plug head but no larger than the the flat area on the underside of the oil pan designed to receive it.
you should be able to find a good fit at an auto parts store or a bike shop.
geezerx is offline   Reply With Quote
Old 09-22-2005   #7 (permalink)
The last time I went into the local bike shop (non-Triumph) for oil drain plug crush washers, I was told that there are basically only 2 sizes on today's bikes: a 14mm one (like the one you've described - this is also the one that I use on my '05 S3) and one slightly smaller (I used this one on my last Honda). Don't worry about it being a "Triumph OEM" crush washer - any bike shop should have 'em.
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 09-22-2005   #8 (permalink)
div2's Avatar
Thanks to everyone for the good advice and information; I'll hit a couple of bike shops tomorrow.
Old 09-22-2005   #9 (permalink)
dgilmore's Avatar
No real need to drain your oil. I just had a crush washer leak because I used it a second time, so I just loosened the drain plug, while keeping upward pressure on it, and when the threads were all out, I quickly pulled the plug, stuck my thumb over the hole, changed the washer with my free hand, and re-inserted the drain plug. All in all, I only lost a small splash of oil. Really surprised me, as usually, those kinds of things are always disasterous.
Dave
2007 Triumph Tiger
2005 Triumph Speed Triple
2008 Ducati Hypermotard S
2005 Ducati ST3
dgilmore is offline   Reply With Quote
Old 09-22-2005   #10 (permalink)
It's just a copper washer so you can anneal it using a blow torch. Take it off the bike first though.
IanB is offline   Reply With Quote
no drain plug crush washer ?? jerryb Twins Technical Talk 10 10-29-2007 11:50 PM
oil drain plug washer SamaR Sprint Forum 24 08-02-2007 10:04 AM
oil drain plug washer peter_s Twins Technical Talk 8 07-08-2007 09:02 PM
Oil drain plug washer RT Twins Talk 8 05-21-2006 09:14 PM
Oil sump sealing washer thumper723 Modifications & Workshop Talk 0 09-28-2004 03:23 PM
