Old 03-19-2004   #1 (permalink)
EVER TRIED TO SOLVE THE PROBLEM OF A NONE EXSISTING REAR BRAKE. IVE MAY HAVE DONE IT. TAKE A MASTER CYLINDER OFF A VFR 800. A SMALL PLATE TO SPACE IT TO THE LEFT. HEY PRESTO, A BRAKE WHEN U BLOW ON THE PEDDLE LOCKS UP.
Old 03-20-2004   #2 (permalink)
Favorite Bike: My Speed Triple 'SS'
Other Motorcycle: My '03 Daytona 955i
I usually spend most of my time trying to stay off of the rear brake.
Pablo is offline   Reply With Quote
Old 03-20-2004   #3 (permalink)
THEN WHY DO THEY PUT ONE ON? PULL UP TO A JUNCTION WITH SOMEONE ON THE BACK. HIT FRONT BRAKE THE BIKE WILL DIVE FORWARD UNDER COMPRESSION. HIT BACK IT WILL EITHER SAG OR STAY LEVEL EITHER WAY SAID PASSENGER IS HAPPY NO BEING TOSSED ABOUT. NAIL ROUND A CORNER, ALWAYS TRAIL THE REAR BRAKE IF NEED TO ALTER SPEED AS IT WILL HELP TO GO ROUND THE CORNER. ANY WAY IT AIN'T HOW U RIDE IT WAS THE FACT IT WAS A **** REAR BREAK. :wink:
Old 03-28-2004   #4 (permalink)
Pete, I have to admit that I'm having a hell of a time understanding what the hell you're saying. Oh, by the way, your "Caps Lock" button is down, you may want to fix that.
teacherkeith is offline   Reply With Quote
Old 03-28-2004   #5 (permalink)
Oh, and don't mind me, I'm just a sarcastic jackass.
Old 03-31-2004   #6 (permalink)
The brake is weak, but still very usable. It makes it really easy to modulate for trail braking through a turn. I actually have locked my rear (unintentionally) when I did a max braking effort one time. The rear had so little weight on it that it locked with little rear brake pressure.
I'm not sure I'd want a rear that locked every time my foot touched it on a sportbike.
Steel braided brake hose for rear brake midliferider Hinckley Classic Triples 4 05-20-2007 04:29 PM
Hot rear rear brake.????? rs_tt Modifications & Workshop Talk 5 04-11-2007 11:55 PM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
Extra hole on front brake bracket? zaqtronic Twins Technical Talk 3 10-17-2006 09:27 AM
D**n.....rear brake gone dazco Twins Talk 47 06-09-2006 08:52 AM
