I had a similar problem. When I had the stock can on, it was running perfectly for the first 3000 miles or so. After that, it started backfiring in the same manner that you described. Sometimes it did, sometimes it didn't. Unlike you, though, I have always used the recommended 89 octane. I have since put an aftermarket pipe on, with the stock tune intact, and it behaves the same way. Hey - it's a Triumph.
Dan
[ This message was edited by: 97TB on 2005-09-10 19:23 ]
