Keyless Ignition - Part Deux! - Page 6 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-19-2012, 02:23 AM   #51 (permalink)
Legend
DEcosse's Avatar
Should not be an issue with this Sombra one - just the initial RFID one.
The issue with the original one was that it created an oscillator between the solenoid and the headlight cut relay; the way around it with the S3/Daytona circuit was to switch the ground to the solenoid off the 'free' N/O pole of the starter cut relay - that is not possible with the Sprint config;
So you would have to isolate the ground to the solenoid via a switch (or conversely, better, to the RFID via a transistor switch)
But again should not be issue on this version as the clutch switch is input to a transistor, which isolates it from the other circuitry.
Old 06-21-2012, 03:57 PM   #52 (permalink)
Thank you for the info. If I go with the Sombra design, I'll probably use the alternate you posted that uses external relays instead of the mod to the Sombra box. Do the relays perform the same isolation as the transitors? (Yep, I'm an electronics noob) Would either of those solutions work if I decided to go with your original RFID design?
DSRW is offline   Reply With Quote
Old 08-02-2012, 04:23 AM   #53 (permalink)
Main Motorcycle: 2009 Bonneville 865
Amazing thread! I was working on my own concoction when I stumbled upon this! DEcosse, you're electrical work is amazing!! Watch for my pm with some questions about doing this to my 'new to me' Bonne :-P
afakhori is offline   Reply With Quote
Old 08-02-2012, 07:07 PM   #54 (permalink)
Main Motorcycle: 2012 speed triple
Other Motorcycle: KTM 250exc
Hi DEcosse. Excellent thread and like so many other people on here have said your work is impressive. I have a 2012 triple and was wondering if this system will work on the new triples. I noticed somewhere on here you mention something about the chipped keys for the immobilizers. Does this mean it can't be done?
2012S3 is offline   Reply With Quote
Old 08-03-2012, 01:04 AM   #55 (permalink)
Main Motorcycle: Speed Triple '08
2012S3, you'll just have to keep the key (or chip) by the ignition where the antenna is built in. If I had a key, I like the idea of keeping it tucked in under the seat wired in series with DEcosse's keyless system; in which case you could immobilize the bike by removing the key. Alternatively I've heard of others getting around the key immobilizers by brazing the chip (the stem of the key) to the ignition barrel close to the antenna; although this would be less secure.
If I can add my 2 cents to DEcosse's design, it would be to use Transil type diode to shunt the relays. This supposedly saves the relay from some possible wear (http://relays.te.com/appnotes/app_pdfs/13c3264.pdf );you'll note that Panasonic is actually discontinuing the parts with built-in diodes, possibly for this very reason.
Here is the part I intend to use:
http://www.digikey.com/product-detai...3-1-ND/2674538
Other than that, I'm just waiting on the parts from Eastern Beaver, and am psyched for putting the system together myself .
THANKS DECOSSE
http://tripleres.blogspot.ca
msowka is offline   Reply With Quote
Old 08-03-2012, 01:58 AM   #56 (permalink)
Legend
DEcosse's Avatar
^ You can certainly use those, (I'm not saying they are not better) but the simple diodes will suffice; just be sure you are only using those for the relay coil spike suppression, and not for the control diodes.
Footnote that I added a layout for the transistor control board to post #4
Old 12-10-2012, 03:16 PM   #57 (permalink)
Main Motorcycle: 98 T595
Ahks's Avatar
I figure since I've classified myself as a geek or nerd to most people AAAANNND I took vocational electronics classes 10 years ago AAAANNND I'm a show off AAAANNND I need a way to hide my ignition barrel...
I pulled the trigger on a K9 Sombra that I found on ebay... new in box... DEcosse is bad for my pocket.
P.S. Thank you DEcosse
http://www.customfighters.com/forums...0&goto=newpost
Ahks is online now   Reply With Quote
Old 12-10-2012, 03:51 PM   #58 (permalink)
Legend
DEcosse's Avatar
You can get down to two relays Ahks - the third that switches to the park lights is really moot since that only is necessary as additional pole to isolate from Headlights when you have key-switch in 'park' position; so just connect that to the headlight pole and eliminate that extra connection.
Also, if removing the switch altogether (I haven't used mine since I installed this!) then you don't need both male & female connector sockets.
Old 12-10-2012, 04:04 PM   #59 (permalink)
Ahks's Avatar
Very good info. I'm trying to slim down the wiring as much as possible as is. I'll put the barrel under the seat or in the trunk just to have in case of emergency and am going to direct wire everything just so the wiring can be hidden better.
Old 12-10-2012, 04:57 PM   #60 (permalink)
Legend
DEcosse's Avatar
Originally Posted by Ahks View Post
... am going to direct wire everything just so the wiring can be hidden better.
Not sure what you mean by that - cutting off the Main Harness Key-switch connector and wiring relays to the wires in harness?
If you do that, you will defeat purpose of carrying key-switch to connect in its place ...
Or maybe I didn't understand correctly.
RFID Keyless Ignition DEcosse Speed Triple Forum 40 12-10-2012 10:39 AM
Political correctness running rampant - Part deux deluxe Biker Hang-Out 53 01-17-2011 05:07 AM
Help on part # for ignition bezel- HeavyDuty Tiger Chat 3 04-28-2009 09:02 PM
The Real Deal, Part Deux McQueen Classic, Vintage & Veteran 2 03-13-2009 01:52 PM
keyless ignition pepe Twins Technical Talk 14 06-01-2008 08:50 AM
