Grip heater installation question - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 11-02-2010, 03:03 PM Thread Starter
Main Motorcycle: 2006 Triumph Speed Triple
q2quest's Avatar
Other Motorcycle: 2002 KTM 400 EXC
I am in the process of installing grip heater elements under my grips. I have read numerous posts about this and like the idea of tapping into the parking light or headlight wires for switched power. The kit did not come with a fuse. I'm wondering if I need to install an inline fuse or is it sufficient just to tap into the existing wire which is surely fused. Your thoughts please.
q2quest is offline
post #2 of 14 (permalink) Old 11-03-2010, 09:02 AM
Main Motorcycle: 2008 Speed Triple 1050
Deathace's Avatar
Other Motorcycle: Suzuki Gladius
I would always put a secondary inline fuse on anything I installed on the bikes wiring just to satisfy safety aspects, more so with heated grips that draw a fair bit of current you could overload the bikes wiring trying to rely on that fuse blowing if there were any problems with the heated grips controller (which is not unheard of).
It is easier to replace a fuse than it is the entire wiring loom.
Russ
And behold, an Orange Motorcycle, and he who sat on it, his name was Deathace. Hades followed with him.
Authority over one fourth of the earth, to beat others with a triple, with speed, with looks, and the loose women of the earth was given to him.
Deathace is offline
post #3 of 14 (permalink) Old 11-03-2010, 02:28 PM
I'm not sure how much current the grips draw but any heating element will draw a significant current. I definitely wouldn't be keen on connecting to parking light wire. You can probably get away with headlight as it will be more heavy duty but may dim the headlight a little. I'd definitely put a seperate inline fuse in - you don't want the first sign somethings wrong to be the headlights dying on a dark country road...
Personally I'd take the (+) straight off the battery with fuse inline and with relay inline running off the park light so its only on when the bikes turned on.
(-) off whatever earthing point you like at the front end of the bike.
slopster is offline
post #4 of 14 (permalink) Old 11-04-2010, 05:17 AM
Deathace's Avatar
+1 on the relay if you want to do it fool proof.
Russ
Deathace is offline
post #5 of 14 (permalink) Old 11-04-2010, 02:31 PM
Main Motorcycle: 09 Triumph S3
Other Motorcycle: 03 Kawasaki KLR 650
Ken09S3 is offline
post #6 of 14 (permalink) Old 11-05-2010, 12:30 PM Thread Starter
q2quest's Avatar
Thanks everyone. I may go with the distribution block down the line, but for now I used an in-line fuse. Heated grips work great. Maybe a little too great. Very hot, even on low setting.
q2quest is offline
post #7 of 14 (permalink) Old 11-09-2010, 05:11 PM
Originally Posted by Ken09S3 View Post
I came across this kit. Might be cheaper to piece it together, but this saves some time.
http://www.twistedthrottle.com/trade...view/2186/596/
Coffee is offline
post #8 of 14 (permalink) Old 11-09-2010, 05:48 PM
Main Motorcycle: Tiger 955i 2006
Other Motorcycle: Matchless,Montesa,Xl 500,
Extra Motorcycle: DR600 , 850 LeMans MK111
... Heated grips work great. Maybe a little too great. Very hot, even on low setting.
Hi q2quest, which grips did you get ?
chopped knuckles is offline
post #9 of 14 (permalink) Old 11-10-2010, 01:19 AM Thread Starter
q2quest's Avatar
Originally Posted by chopped knuckles View Post
.... q2quest, which grips did you get ?
I bought the Symtec kit and used them with a new set of the factory grips. The install came out great. I also installed a set of Pro-Taper hand guards to prevent wind chill to my fingers. With those two together I don't think I'll have to worry about cold hands again.
Paul W.
"Motorcycle racing makes heroin addiction seem like a vague wish for something salty"-Peter Egan
q2quest is offline
post #10 of 14 (permalink) Old 11-10-2010, 03:49 AM
Got a photo of the hand gaurds , and showing how they mount ? which model pro taper,?
Thanks again..
Heater grip switch Sprint 955i kiwijohn Sprint Forum 4 05-02-2010 06:34 PM
Even another heated grip question. OK, three. elevens Sprint Forum 23 11-28-2008 11:10 AM
Oxford Heated Grip installation ziaduck Tiger Workshop (archive) 5 01-04-2008 08:47 PM
Heated grip question. triumphstluster Sprint Forum 2 04-16-2006 04:28 PM
