Compufire 55402 regulator install information - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 88 (permalink) Old 09-05-2010, 11:43 PM Thread Starter
Main Motorcycle: 2012 Tiger Explorer
I have had some stator problems in the past and going off of the good thread that DEcosse put out, not only did I need to put a new stator in, I needed to put a new regulator in. I went with the Compufire 55402 regulator. I figure I would pass on what I know and see about giving back to the community.
The first thing to know is as far as of this post (Sept, 5th, 2010). No one seemed to have the regulator so I needed to get it from the factory itself. I did ask the sales person why no one seemed to have it. He told me that it is going to eventually be available through all of the normal retail channels, it is just taking a while. The part itself is not new, it is just new having it as a separate component. In the past it was always available as part of a kit.
So bottom line, check Dennis Kirk, if it says available soon, just call the compufire factory and get it directly from them.
Here is a picture of the new regulator next to the original.
As you can see the Compufire is a little smaller than the original, it is a little higher but there is plenty of vertical room so that is not an issue. As luck would have it, the holes even matched up pretty close. I had enough slop in the mounting holes on the bike that no modification was necessary. Here is a picture of the new regulator on top of the old one. The pic isn't the best but the idea is conveyed.
The Compufire comes with weather pack connections for the stator and an empty female weather pack connection.
The nice part with this is you can go down to your local NAPA store and get the missing coponents. They should give you 3 male connectors. (Male metal pieces go in the female plastic part). They should give you something that looks like this.
The other nice thing is the power connection comes with a female spade, but also an inline fuse connection so the spade can plug into it and then the other end of the inline fuse has a connection to go on the bolt on the battery. It gives a little more flexibility that way. The 40 amp fuse is because the regulator is a 40 amp model.
I put the spade into the fuse and hooked it directly to the battery. The original regulator connection has 7 wires coming out of it and the Compufire has 5. 3 of the wires are for the stator and the other ones are ground and power. The original regulator has 2 power wires and 2 ground wires. If you trace the wires you will find they merge and are in the midway between the battery and the rest of the electronics.
What happens is if you don't use the 4 prong connector and just hook the power and ground to the battery is you have a 40 amp fuse from the regulator to the battery and from the battery to the other electronics you have a 30 amp fuse. (It's fuse 11 in the fuse box.) Leaving the 4 prong unconnected doesn't have any effect because there is still the normal wire that goes from the battery to the fuse box. I would have a pic but didn't want to get in trouble taking a pic of the service manual. The short version is think of a 3 way connection, one goes to the battery, one to the fuse box and one to the original regulator. Having the regulator not connected doesn't bother the battery and fuse box. If this isn't clear feel free to add a question to the post.
Have fun adding a Compufire 55402 series regulator to your machine.
vsteel is offline
post #2 of 88 (permalink) Old 09-22-2010, 10:22 AM Thread Starter
For those looking for the Compufire information thier website is:
http://www.compufire.com/
and their phone number is:
Toll Free: (888) 467-7953
vsteel is offline
post #3 of 88 (permalink) Old 09-22-2010, 11:33 AM
Main Motorcycle: Triumph Speed Triple 2006
rnexussix's Avatar
Looks like they manufacture stators for HD and package it together with their R/R. Perhaps they should add Stator + R/R package for S3 & Daytona.
Vsteel, thank you for the write up. What are the voltages you are getting on the battery during idle and higher RPM ?
rnexussix is offline
post #4 of 88 (permalink) Old 09-23-2010, 10:23 AM Thread Starter
That would be great if they bundled a stator and regulator. I don't know if it would happen, but it wouldn't be hard for someone to come up with some kind of package deal for people.
I measured voltage at 14.3 no matter what RPM. When you first fire it up it will take about 5 seconds for it to come up to 14.3 but after that it is rock solid.
vsteel is offline
post #5 of 88 (permalink) Old 09-23-2010, 02:16 PM
Main Motorcycle: 2007 Speed Triple
Other Motorcycle: 2007 Rocket 3
Extra Motorcycle: 2004 Suzuki Hayabusa
Interesting vsteel......Let us know how it works after your test/tune stage......I just completed the MOSFIT upgrade and am very happy.......Keep us posted......Cheers.
redline07 is offline
post #6 of 88 (permalink) Old 09-23-2010, 04:22 PM
DEcosse's Avatar
That would be great if they bundled a stator and regulator.....
Why would you need to replace the stator as well if you are installing a series Regulator?
(unless it is actually bad)
DEcosse is online now
post #7 of 88 (permalink) Old 09-23-2010, 10:09 PM
rnexussix's Avatar
DEcosse,
Would you happen to know how does the electrical current induction happens in the S3's stator i.e. with a permanent magnets, or external coils. (I had a chat - a sanity check really, with electrical engineer re. sink vs. series R/R's).
post #8 of 88 (permalink) Old 09-24-2010, 01:56 AM
DEcosse's Avatar
post #9 of 88 (permalink) Old 09-24-2010, 08:58 AM Thread Starter
I was one of those who would have taken advantage of a package deal. After burning out the second stator on my motorcycle I replaced it as well as the regulator to try and stop the constant stator failures.
So far ~700 miles and it is working great.
vsteel is offline
post #10 of 88 (permalink) Old 09-25-2010, 02:17 PM
rnexussix's Avatar
Vsteel, what was the mileage between the two burned out stators ?
Upgrade Regulator Rectifier Install WardenRoss Maintenance Tips and Tricks for your Sprint 68 12-21-2012 03:34 PM
Information Please Skyblue62 Air Cooled Twins Technical Talk 8 08-12-2010 03:23 AM
FH012AA Rectifier/Regulator Install NorthernThrux Air Cooled Twins Technical Talk 8 08-05-2010 04:33 PM
Help --- I need some information dick mitchell Air Cooled Twins Technical Talk 7 08-07-2009 10:47 PM
Looking for some information on 82 Executives SprintST Classic, Vintage & Veteran 3 11-17-2007 10:16 PM
