Old 08-10-2005   #1 (permalink)
Favorite Bike: '05 Speed triple
crudmop's Avatar
Other Motorcycle: Current Collection:
Extra Motorcycle: 01 996 -03 636 -98RS 250
Does anyone know the hex size for the front axle/axle nuts on an '05 s3?
Actual tools, or Metric bolt trick size will do
Thanks!
crudmop is offline   Reply With Quote
Old 08-10-2005   #2 (permalink)
Lom
Sorry, not in the service manual.
Assuming you may also need the torque settings:
Front wheel spindle/axle bolt : 110Nm
Front wheel spindle pinch bolts : 20Nm
I'M IMMORTAL
well...so far.
http://www.triumphrat.net/albums/alb.../aad.thumb.jpg
Lom is offline   Reply With Quote
Old 08-10-2005   #3 (permalink)
Thanks!
05 S3 Front axle hex size 22mm, as for the rear wheel nut that would need a 46mm socket.
Have Fun!
aikojo is offline   Reply With Quote
Old 08-10-2005   #4 (permalink)
crudmop's Avatar
Ahhhh you guys rock - thanks to the both of you for the info.
Luckily, my gf's duc has the same sized rear nut as the s3 1 less tool to buy
Old 08-10-2005   #5 (permalink)
Is the front spindle really that much? Where did you get the info?
HarriS is offline   Reply With Quote
Old 08-10-2005   #6 (permalink)
Are the wheels from a 2003 S3 interchangable with an 05?
just wondering.
I speed, Klugman
Klugman is offline   Reply With Quote
Old 08-10-2005   #7 (permalink)
ES3
just wondering.
Not the front wheel, I know. The brake discs have a bit larger distance from each other, because of the radial mounted brake calipers.
No more Triumph
ES3 is offline   Reply With Quote
Old 08-10-2005   #8 (permalink)
Thanks.
I speed, Klugman
Bonnie axle nut size? NortonBrian Twins Technical Talk 7 01-09-2008 09:49 AM
Scrambler Axle nut size Brumos Twins Technical Talk 2 08-23-2007 05:53 PM
Rear axle nut size on 06 S3? tsc17 Speed Triple Forum 3 06-08-2006 07:52 AM
rear "axle" nut size for '04's redsled Speed Triple Forum 6 09-14-2005 10:15 PM
Rear axle nut size triumphrider99 Hinckley Classic Triples 3 08-04-2005 03:59 PM
