Speedo CableGauge Cluster - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-31-2005, 12:13 AM   #1 (permalink)
So I finally get a weekend to take the triple on its first real trip and stretch its legs a little bit and of course something needs to break. I was prolly doing about 120-130 and all of a sudden i hear a snap and my speedometer stops working, pull into a gas station and find that the cable has actually broken off the threaded metal piece where the cable screws into the gauge cluster\speedometer(the silver part, now it's just a little brass nub sticking out). I assume the wind pushed the cable back(although not enough to tear the rubber loop on the front fender) and caught the tire. In any event anyone have any idea whether i need to get a whole new gauge cluster? I assume the speedometer is not a seperate entity. Thanks.
On the bright side though I guess I'll be getting free mileage until it gets fixed. :razz:
qc415 is offline   Reply With Quote
Old 07-31-2005, 03:33 AM   #2 (permalink)
rat
It's unlikely the wind that ripped the cable out - more likely it was cross- threaded or loosely fitted in the first place. Some tw4t recently ripped mine out from the front wheel with the footpeg of his moped so I know it's about 35 euros from yer local Triumph (st/d)ealer for the cable. Comes with all the necessary fittings.
If the threads are stripped on the speedo housing wrap them with some ptfe tape from a plumbing supplier.
/rat
rat is offline   Reply With Quote
Old 07-31-2005, 02:02 PM   #3 (permalink)
its not that the threads are stripped, like the metal that was the threading broke off completely so just the brass receiver that was inside the threading is exposed.
Old 07-31-2005, 02:03 PM   #4 (permalink)
instrument cluster joejay70 Sprint Forum 0 06-30-2007 10:57 PM
Figuring out the Speedo ratio-using alternate speedo clamp007 Twins Technical Talk 0 05-04-2007 02:15 AM
Anyone have a KMH speedo to trade for a MPH speedo? Suncoast Sprint Forum 5 07-24-2006 08:17 PM
Instrument Cluster OG-MOON Speed Triple Forum 0 06-09-2006 07:16 PM
Removing Speedo Cluster on 05 ST ajbloor Sprint Forum 5 06-08-2006 09:28 PM
