On 2005-07-22 20:45, SCORPIODRAGON wrote:
A Question , Clipons, the pics from Tervuren at the French Link look to say 52 mm. and looking at specs. from another site (powersportsnetwork.com)or Triumph.co itself look to say 45mm. Is there something I am overlooking?
The confusion here is because these are inverted forks. Technically these are 45mm sliders inside 52mm fork tubes. The number you are looking for is the 52mm, as this is the part the the clipon attaches to. However, if you were to order a replacement fork, you would order a 45mm inverted fork (the inside.)
On old style forks the inner slider was the part that the clipon attached to, and was therefore the number you would be looking for.
Everything clear?
