Fuel line leaking after metal coupling install - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 03-28-2010, 08:04 PM Thread Starter
Main Motorcycle: 2003 Speed Triple
staves's Avatar
Other Motorcycle: None. . .
Extra Motorcycle: and none
I was feeling pretty good after getting those plastic female fuel line fittings out of my '03's gas tank in one piece. I replaced them with metal fittings (and I put new o rings on the male part of the fittings which were already replaced with metal ones) and now the lower/silver fitting is leaking like a sieve when the bike is running.
I used a proper sealant on the threads and it definitely seems like the leak is occurring where the male and female couplings fit together.
I used 1/4 BSPT Valved CPC Coupling Bodies. Can anyone confirm that I'm using the right size? Any ideas? I'm trying to save a few bucks by just buying the female fittings vs. the full kit from Team Triumph.
Thanks!
2003 Speed Triple
staves is offline
post #2 of 12 (permalink) Old 03-28-2010, 08:45 PM
DEcosse's Avatar
Does it leak when the male is not connected?
If it does, leak is in female side
If not, it is the male o-ring.
DEcosse is online now
post #3 of 12 (permalink) Old 03-28-2010, 09:04 PM
PhilM's Avatar
Thanks!
Where did you get just the female fittings? Cost? I need a set too.
1/4bspt is the correct thread.
Do the female fittings have the "Viton" o rings which are gasoline resistant?
Are you sure the o rings you replaced didn't get damaged when you put the couplings together? (easy to do)
PhilM is offline
post #4 of 12 (permalink) Old 03-28-2010, 09:57 PM Thread Starter
staves's Avatar
Thanks for the info. Do you mean the o rings on the male fittings? If so, I just got the OEM o rings from Triumph. I feel stupid ordering o rings from Triumph but I had a bunch of other stuff to order.
I definitely could have damaged the new o rings because I've had the tank off five times over the past day.
What size "Viton" o rings are you using? Where can I get them?
I bought the female fittings here for about $30 shipped (in US) for both:
http://quickcouplings.net/osc/produc...dabfc1902f3ccd
2003 Speed Triple
staves is offline
post #5 of 12 (permalink) Old 03-28-2010, 09:58 PM Thread Starter
staves's Avatar
Thanks for the reply. No leak when they're not connected so I suspect I buggered the new o rings with multiple tank removals yesterday.
2003 Speed Triple
staves is offline
post #6 of 12 (permalink) Old 03-29-2010, 08:43 AM
PhilM's Avatar
I got the viton rings at Autozone but I had to purchase an assortment to get them.
The Buna N o rings in your new female fittings will eventually leak as they are not rated for gasoline. Triumph used Buna N in the original fittings, mine are now leaking when I uncouple them. Fortunately it takes a long time for them to deteriorate. They cannot be replaced.
Your last post said "no leaks when connected', did you mean that?
PhilM is offline
post #7 of 12 (permalink) Old 03-29-2010, 10:28 AM Thread Starter
staves's Avatar
Phil - I meant to say they don't leak when disconnected, fixed now in original post.
The ever-so-helpful people at Quickcouplings.net just told me they can sell the correct size Buna N or Viton rings for the male fitting. Buna N @ $0.20/ea. and Viton @ $0.60/ea.
Scott
2003 Speed Triple
staves is offline
post #8 of 12 (permalink) Old 03-29-2010, 03:53 PM
PhilM's Avatar
Good to know! Thanks.
PhilM is offline
post #9 of 12 (permalink) Old 03-29-2010, 04:20 PM Thread Starter
staves's Avatar
Phil - I just noticed we have the same year and color Speedy. Nice bike!
2003 Speed Triple
staves is offline
post #10 of 12 (permalink) Old 03-30-2010, 06:25 PM
PhilM's Avatar
Thanks. Just put on a pair of Tec Spec tank pads today.
If you weren't so far away, we could hook up for a ride!
Have relatives in Sheridan, we get up there once a year, ride down around the Starved Rock area.
I ordered a pair of female couplings from "Quickcouplings". Thanks for the lead.
PhilM is offline
Broken fuel coupling DobroDog Tiger Workshop (archive) 16 09-13-2010 05:22 PM
Fuel coupling orientation bigred900 Tiger Mods & Bolt-Ons (archive) 3 02-06-2010 01:42 PM
Which fuel coupling? Please advise. Skidpan Tiger Workshop (archive) 4 06-25-2008 12:40 PM
Metal fuel line coupling DobroDog Tiger Workshop (archive) 5 03-09-2008 11:14 AM
Leaking fuel line on my '01 Hokie Sprint Forum 20 08-09-2006 06:42 PM
