hi just started my 2005 1050 speed triple after replacing rear shock and linkage as it was siezed solid. Its been stood about 2 months while i was working on it, battery disconnected. it started up no probs but the rev counter did not do its usual sweep and now does not work at all and if i try to set the gear change lights to see if i can get it working that way all that happens is i get a flashing number 2 in the speedo readout box and the only way to clear that is to switch off the ignition has anybody had similar or got any ideas
