How do folks connect up their accumates - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearHonda Powersports Motorcycle.comOntario Tourism
Old 03-15-2010, 07:46 AM   #1 (permalink)
Favourite Bike: Speed triple, Ducati 888
JK1050's Avatar
Hi all,
Just Got my 05 model Speedie and was wondering how do folks connect up their trickle chargers, on the sprint it was easy just plug and go. I was wondering if people just lifted the seat and connected st to the battery each time or routed the cable out somewhere or even if they installed a socket somehere on the bike.
I was thinking that I'd route the cable out from under the seat somewhere or possibly fit a socket.
Just wanted other peoples ideas so I could get it right first time.
Thanks Jeff.
JK1050 is offline   Reply With Quote
Old 03-15-2010, 08:54 AM   #2 (permalink)
jaz
Favourite Bike: Speed Tripple
jaz's Avatar
I use have the wired connection with the plug on the end that came with my optimate, this has a splash cover over then end, then just take the seat off and connect when needed.
Though I find I only need it over winter, if you need it in the summer then you need a new battery or to get your arse out on the bike more often
Though watch the fuse holder, I found it had come a little unscrewed and when starting the bike it could "trip" the whole system with a click and go dead, turn it off wait a few then on again and all would be well but worried the hell out of me for a while (also lost the top speed in the ECU... grrrr )
jaz is offline   Reply With Quote
Old 03-15-2010, 09:42 AM   #3 (permalink)
JK1050's Avatar
Don't worry Jaz come the good weather my arse will be on the bike lots.
Its just that I normally kept the sprint plugged into the acumate all the time it was in the garage and was thinking I'd do the same with the speedie and was hoping not to have to keep lifting the seat.
I;ll see what other ideas people come up with here.
Jeff
Old 03-15-2010, 09:57 AM   #4 (permalink)
Favourite Bike: '01 Speed Triple
Just run the pigtail from the battery out under the seat somewhere, and ziptie it to the frame. That way you can connect it when you park without removing the seat.
Speed3 is online now   Reply With Quote
Old 03-15-2010, 05:54 PM   #5 (permalink)
DEcosse's Avatar
If you don't have one, you can get the accessory direct from accumate - http://www.accumate.com/612/a_weather.php
I have mine coming forward from the battery and coming out on left side just above sprocket cover - little more unobtrusive there
T'Rat.net BOTM November 2009
Old 03-16-2010, 04:55 AM   #6 (permalink)
JK1050's Avatar
Thanks will check out availability in the uk.
All I had was the standard lead that has the croc clips on it. I've chopped these off and fitted eyelet crimps so I can connect up at the moment but the weather proof one has to be the way to go.
Old 03-16-2010, 05:09 AM   #7 (permalink)
DEcosse's Avatar
Here you go!
http://cgi.ebay.co.uk/Optimate-Accum...1/400072710899
http://www.thegreenreaper.co.uk/ShowDetails.asp?id=827
Old 03-16-2010, 08:21 AM   #8 (permalink)
jaz
jaz's Avatar
Good idea, TBH i never even though of running it outside the battery compartment
Old 03-16-2010, 01:26 PM   #9 (permalink)
DEcosse's Avatar
Picture worth a thousand words they say!
I have the Optimate 4 & Battery Tender models, both of which use the SAE connector (as opposed to the Accumate type) which you see in the pics.
You could of course bring it out on the clutch cover (right) side if that is more convenient for your own garage parking circumstances.
Old 03-16-2010, 01:33 PM   #10 (permalink)
JK1050's Avatar
Hi,
That routing and installation looks neat and tidy, may well do something similar. Just looking on the accumate site and I found this.
http://accumate.co.uk/it020002.htm
Something similar to what I had on the Sprint.
Anybody tried hooking this up on a bracket and mounted somewhere un obtrusive.
Jeff
What does this connect to and is it important? Jaxx Street Triple Forum 8 01-08-2011 12:43 PM
Do These Connect to Anything? Tom Herold Sprint Forum 4 09-09-2008 07:39 AM
03 S4 - What does this connect to? speed4grl Triumph SuperSports 5 06-22-2008 12:40 PM
Where does this connect? Cardje Twins Technical Talk 1 01-25-2007 02:25 AM
Heated grips on S4... where to connect to ? neil1052 Triumph SuperSports 6 03-12-2006 05:13 PM
