Quick Throttle Mod - Page 12 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Old 06-24-2012, 11:36 PM   #111 (permalink)
Main Motorcycle: 2012 Triumph Speed Triple
I tried the PVC mod. It cannot be done on an '11/'12 S3 without grinding tabs out of the throttle housing.
scoutpilot is offline   Reply With Quote
Old 07-02-2012, 04:14 AM   #112 (permalink)
Main Motorcycle: 07 S3
I just ended up ordering the rizomas grips just waiting to install
Björk is offline   Reply With Quote
Old 07-03-2012, 08:16 PM   #113 (permalink)
Main Motorcycle: 2000 Daytona 955i
Other Motorcycle: yamaha YZ-250
I saw this and got an idea. I have a yamaha 2-stroke dirt bike and the throttle tubes are very similar. I put one on the bike I had laying around and it fit with no mods done to the housing. It has a larger pull diameter.
biff101 is offline   Reply With Quote
Old 07-03-2012, 10:07 PM   #114 (permalink)
Legend
DEcosse's Avatar
Originally Posted by biff101 View Post
... I have a yamaha 2-stroke dirt bike and the throttle tubes are very similar....
The 97-01 series triples have single-pull throttle cable - everything after that has dual cable
Old 07-04-2012, 03:01 PM   #115 (permalink)
All the 4 stoke dirt bikes use the push-pull cables. maybe this helps.
Old 08-12-2012, 02:01 PM   #116 (permalink)
Main Motorcycle: t1050
I can confirm for my 2006 it can't be done either. Oh well, more reason to get nice rizomas
vrus is offline   Reply With Quote
Old 08-12-2012, 02:23 PM   #117 (permalink)
Main Motorcycle: custom harley
Other Motorcycle: 71 TR6
Extra Motorcycle: varies
something to consider
the quick throttle mod causes the throttle cable to make a sharp bend right at the barrel.
I have been broken down beside the road, twice because of a quick throttle
I think I have had 4 broken throttle cables in over 30 years of riding (street and dirt), and two of those were within 2 1/2 years of each other. Both with different throttle assemblies, but both with a quick throttle mod.
I would hazard a guess that 65% of the broken cables I see in the shop have this mod
If you decide to do this, add throttle assembly inspection to your regular maintenance regiment
Lee H is offline   Reply With Quote
Old 08-14-2012, 12:26 AM   #118 (permalink)
Main Motorcycle: 2002 Daytona 955i DSSA
Pro tip, thanks
DSSA955i is offline   Reply With Quote
Old 10-03-2012, 06:06 PM   #119 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Originally Posted by Martin_R View Post
Yes. Except with a good tune and throttle cables with zero slack the pickup is not abrupt at all. You can soften the pickup further in TuneEdit by richening the overrun mixture a bit.
Kindly elaborate. I'll be tackling this abruptness on my '03 955i (S3) in the next couple of weeks. We can take this off-thread if you like.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 01-27-2013, 10:36 PM   #120 (permalink)
Main Motorcycle: 2012 S3 Red
Triplewannabe's Avatar
Other Motorcycle: 2011 GSXR 1K Blk.
I took the play out on my 2012 & it's great....little adjuster right behidg the right headlight.
Triplewannabe is online now   Reply With Quote
Quick turn throttle dolson Sprint Forum 29 11-03-2011 11:44 AM
1/5 Quick Throttle 5.0 Will Speed Triple Forum 11 12-20-2009 01:23 PM
Quick Action Throttle Pickle Jim Sprint Forum 8 03-04-2008 03:04 PM
Throttle too quick on 06 S-3 HiVel Speed Triple Forum 9 01-06-2006 12:27 PM
Quick throttle ? ( 06'ST) ST Sprint Forum 2 07-30-2005 02:58 PM
