Quick Throttle Mod - Page 10 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 03-13-2012, 07:10 PM   #91 (permalink)
Main Motorcycle: Can't have just one!
PJFZ1's Avatar
Other Motorcycle: FZ1
Extra Motorcycle: Hypermotard
Thanks DEcosse!
If loud pipes save lives, Imagine what learning to ride that thing could do!
PJFZ1 is offline   Reply With Quote
Old 04-10-2012, 09:54 AM   #92 (permalink)
Main Motorcycle: Triumph
You can shorten the pull about 8% with some super glue and a large zip tie. Done it to several bikes over the years...
SquireSCA is offline   Reply With Quote
Old 04-12-2012, 12:17 PM   #93 (permalink)
Main Motorcycle: Late '07 S3
V-twinner's Avatar
Other Motorcycle: RC51
Extra Motorcycle: VTX1800
Originally Posted by DieselGeek View Post
Buy a set of Rizoma grips , sportline or lux , pick the biggest camin the kit .
get max slack at the top adjuster and some more slack at the TB. install the grips . adjust the cable.
/thread
This is the definitive answer for folks not wanting to modify either the R6 throttle or OEM bits.
Installed in about 15 minutes (both sides), and only challenge was fitting my fingers of butter into the TB area to attack the adjusters.
NB: Loctite the crap out of the pinch bolts. They have a habit of loosening up, particularly on the clutch side.
Thanks Norm!
V-twinner is offline   Reply With Quote
Old 04-16-2012, 07:55 AM   #94 (permalink)
Main Motorcycle: Black '03 Speedy
Other Motorcycle: There are other cycles?
Just did my first track day this season and feel I need to be able to get to WOT with a little less throttle rotation. Installed the larger cam that came with my Rizoma grips (been using the smaller cam, the one that matches the stock cam, for some time now) per some of the instructions in this thread. Slackened the cables and was able to get it installed but the throttle is not smooth. It doesn't bind, but I can feel what seems to be the cable rubbing somewhere in there. Could the cable be rubbing too much on the plastic guides at the handlebar end? Should those plastic guides be trimmed back to accommodate the larger cam?
Any guidance would be very much appreciated.
03Speed3 is offline   Reply With Quote
Old 05-22-2012, 04:41 AM   #95 (permalink)
Main Motorcycle: '07 Speed Triple 1050
I have got the opportunity to purchase a second hand throttle tube and grip from a bike dismantlers. It says it's from an R6 1998 - 2002. Does anyone know if this year part will have the large cam?
Steiny is offline   Reply With Quote
Old 05-22-2012, 04:54 AM   #96 (permalink)
Main Motorcycle: Speed3 -09
Martin_R's Avatar
^Probably not larger. You could ask them to measure diameter, if it is larger than 36.5mm.
Martin_R is online now   Reply With Quote
Old 05-22-2012, 05:01 AM   #97 (permalink)
Originally Posted by Martin_R View Post
^Probably not larger. You could ask them to measure diameter, if it is larger than 37.5mm.
Does that relate to the outside or the inside?
Old 05-22-2012, 05:09 AM   #98 (permalink)
Martin_R's Avatar
? The cam size where the cables ride is what matters.
Also I have to correct my previous post, OEM is 36.5mm.
Old 05-23-2012, 07:21 PM   #99 (permalink)
Main Motorcycle: S4
Other Motorcycle: 3.2L '88 e30
Extra Motorcycle: 2006 Xterra
I just did this 22CENTS throttle mod to my bike last night.. Hole mole did it need it:
http://www.triumphrat.net/triumph-su...-question.html
10x cheaper than the R6 throttle tube.
No need to cut/grind cable housing.
Took me long to sand the PVC cut-out than to disassemble and assemble the whole chebang.
I did crazy glue the "adapter" in place with a few dabs. Nothing that can't be undone.
Even considering stepping up the OD to be close to 40 or+. Atleast now i can reach WOT without having to change my grip - which is really shady when you try to break/rev match.
-etxx
etxxz is offline   Reply With Quote
Old 05-24-2012, 09:08 AM   #100 (permalink)
Main Motorcycle: 00 955i sprint st
doing this tonight!!
-etxx
dichotomous is offline   Reply With Quote
Quick turn throttle dolson Sprint Forum 29 11-03-2011 11:44 AM
1/5 Quick Throttle 5.0 Will Speed Triple Forum 11 12-20-2009 01:23 PM
Quick Action Throttle Pickle Jim Sprint Forum 8 03-04-2008 03:04 PM
Throttle too quick on 06 S-3 HiVel Speed Triple Forum 9 01-06-2006 12:27 PM
Quick throttle ? ( 06'ST) ST Sprint Forum 2 07-30-2005 02:58 PM
