A 5/8” master cylinder will give you increased resistance at the lever because it’s pushing the fluid through the same bore tube as before, and an increased pressure on the pads at the caliper end. Useful if the lever feels “soggy”, though I’m not sure if the ‘05 comes with braided lines. If not, that would be my first upgrade...
Theoretically, it shouldn’t make any difference whether you’re running 4 or 6 pot calipers; the larger piston in the 5/8” cylinder just pushes more fluid down the line. The standard master cylinder is 3/4”, so it’s not a *major* increase.
If anything, you’ll lose a bit of braking “feel”, but gain more bite at the pads, so you’d just need to re-learn your braking technique.
/rat
