Sweet bike S_Mues.
There are several threads about coolant on here but they all seem to say different things. If you ask me, any coolant should be fine provided you take care of it (i.e., replace it each year or every other) it's really not very expensive or time consuming. I am going to run Prestone brand 30/70 ethylene glycol/water by volume and change it every year (people in the colder parts may want to bump that up a bit). By changing every year, I dont have to worry about getting every drop each time. All this being said said, under the correct conditions ethylene glycol is capable of polymerizing or even itsel being oxidized. This polymerization will manifest as a sludge or thick goo with a very high viscosity (not very good for cooling).
So I think the moral is, take care of your bike and she'll take care of you.
BTW, everyone knows SILVER is way faster than green!
--festinotria
"Wisdom is the reward you get for a lifetime of listening when you would prefered to have talked"
