Engine Won't Start, Need Help. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-15-2009, 07:48 PM   #1 (permalink)
Favourite Bike: 2007 Speed Triple
2007 Speed triple
-just performed oil change (started it up right after, ran it for a few minutes and called it a night)
So this morning, I wasn't able to start it up. It does sound like there is a 5 second delay from turning the ignition switch on and hearing the fuel pump and charge take place. I did smell raw fuel, and my battery was only giving out 12V across the terminals (which I read may be an indication that my charge is low).
So I was thinking a new battery and cleaning/replacing the plugs. Does anyone have a guide on how to access the plugs? I can't seem to find one. Or, is there anything else I am missing that I should look at that might give me a better indication of whats wrong?
Thank you.
dkyamada is offline   Reply With Quote
Old 11-16-2009, 03:10 PM   #2 (permalink)
Favourite Bike: Speed Triple
Other Motorcycle: Ducati Street Fighter
Plugs are easy:
1) Remove tank: don't get the two small rubber hoses on the left hand side mixed up when you reinstall.
2) Remove the air box
3) Unclip the coils and pull the coils up. I do this one at a time.
4) Remove one plug at a time. left plug is a LITTLE tricky, you'll see.
5) Put new plugs in with a bit of anti-sieze on the threads and torque down to spec.
6) Pop on each coil, should hear/feel a mild "click." Reconnect wire harness to each coil.
7) Reinstall airbox, tank.
Whole thing takes 30 minutes and is SIMPLE! While everything is off take a few minutes to do some cleaning in there. Make sure no wires are rubbing/wearing away the sheaths, signal connections are tight, lubricate throttle cable/spring.....clean out your throttle bodies/butterfly valves since they will be right there staring at you. Maybe pop in a new airfilter if it's getting close while you are in there. etc etc.
29138 is offline   Reply With Quote
Old 11-16-2009, 06:10 PM   #3 (permalink)
Favourite Bike: Early 07 Speed Triple
thewolf-Oz's Avatar
PM sent to dkyamada
thewolf-Oz is offline   Reply With Quote
Old 11-16-2009, 10:04 PM   #4 (permalink)
Thanks for the help. I'll get crackin on this soon.
Old 11-17-2009, 07:07 AM   #5 (permalink)
12.0v is a dead battery.
Power-Tripp is offline   Reply With Quote
Old 11-18-2009, 03:21 PM   #6 (permalink)
New battery and I'm up and running. Thanks for the help.
Old 11-20-2009, 12:05 AM   #7 (permalink)
Favourite Bike: '08 Speed Triple
Other Motorcycle: '04 Royal Enfield-sidecar
Extra Motorcycle: '91 CBR 600 F2 (track)
I've got a similar issue. Checked my battery and it was 11.5 volts. Put it on a Battery Tender overnight. We'll see how it goes in the morning.
jfeagin is offline   Reply With Quote
Rebuilt engine won't start kredge Daytona Deliberations 28 12-29-2009 10:51 AM
Can't start the engine ksdog7 Maintenance & Workshop Talk 4 09-19-2008 08:09 AM
engine won't start GoinPostal Sprint Forum 6 09-08-2007 01:58 PM
Can't start the engine Palle Sprint Forum 19 02-06-2007 06:17 AM
Warm engine won't start Mindawass Twins Technical Talk 4 01-08-2007 01:21 PM
