Originally Posted by Billybob
In the US there was factory sponsored warranty fix (at no cost to the owner); this fixed the problem on my bike. Might want to ask your dealer, but could be a problem because your bike is out of warranty.
That fix was to replace the pistons with the 675 Daytona (coated) pistons. The later versions (late 2006) had this mod incorporated from the factory.
As noted by BillyBob, there was a courtesy good-will on this replacement - definitely worth checking into. I believe this was covered in the UK and not strictly just a US thing.
If Triumph UK won't do it at this point, you are on your own to do the same thing - which is not inexpensive.
Many prior to this fix coming along, traded out their calipers for GSXR Tokicos which are essentially a plug n play replacement and readily available on EBay. Probably cheaper option if on your own dime (or that should be 10p piece I guess
While you're at it, fit a GSXR radial master cylinder too.
