Shape is the same, except for the metal tank's visible (and arguably uglier) rolled seam between tank & frame. Front mounting point is different: late 07 onwards has a peg on the frame that the tank slides onto. Plastic tank bikes have a bolt. My guess is that the peg setup will fit on a pre metal tank frame.
Fuel pump plate and fuel pump is also different on later bikes. I am pretty sure these are not interchangeable. You would need all the later hardware to go with the metal tank, the outer shell is not enough.
I don't remember if the rear mounting point is exactly the same, but would guess yes, as the late 07 bikes already had metal tanks and Triumph rarely likes changing things like frame lugs.
