Clip-ons give you a little more feedback from the front wheel, and also change your riding position to get you out of the wind a bit. They are easy to put on.
The Speed Triple has 45MM fork uppers, so you'll need to buy the correct size but most manufacturers make this size since it is very common. You can probably get a pair off the web fairly cheap.
Also, if you get sick of them changing back to bars wouldn't be that big of a deal.
