EPG Moto
Trident-Exhausts.comSportbikeTrackGearEPG MotoMotorcycle.com Classifieds!Riders DiscountBritish Motorcycle Gear
Old 09-25-2009, 03:03 PM   #1 (permalink)
Favourite Bike: speed triple 1050
Other Motorcycle: piaggio scooter X cb250
SW Motech rack broke my sub frame
hello every one first time writing on the web site but had to let every one know about my subframe which as broken after fitting a sw motech rack and givi top box i did not carry any thing heavy in it just put it on when my daughter road pillion
madcount69 is offline   Reply With Quote
Old 09-25-2009, 03:22 PM   #2 (permalink)
Favourite Bike: 1996 Speed Triple
wiayeman's Avatar
Other Motorcycle: 2008 Speed Triple (matt)
Extra Motorcycle: 2000 Suzuki SV650 (track)
Is it made specifically for the S3? Looks like a lot of leverage there. I don't think it would take much to break the subframe considering how far it hangs off the back.
better dead than red
wiayeman is offline   Reply With Quote
Old 09-25-2009, 03:32 PM   #3 (permalink)
yes was made for the speed triple had it the bike a number of times with no problem but yesterday when we where out there was a cracking noise and that was that
Old 09-25-2009, 03:53 PM   #4 (permalink)
Favourite Bike: 2008 Speed 3
rms_z28's Avatar
Looks like your rack is different than what is currently out there for the '08 and on. Notice the legs that mount to the passenger foot pegs in this picture http://www.twistedthrottle.com/trade...view/4585/243/
Probably because they later found out that the older form of mounting caused too much stress on the sub frame... Hmmm?
I'm low on gas and you need a jacket!
rms_z28 is offline   Reply With Quote
Old 09-25-2009, 03:58 PM   #5 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Bummer. Looks like the box you have on there will put the whole assembly well over the 7.5kg (16.5lbs) max load limit. The box + adapter plate alone might push you close and then there was the additional load of passenger leaning on the box.
I had the same rack on my old bike for few years, but I only used a small soft bag on it and only on longer trips. No problems.
Probably. SW Motech has also dropped the max load limit on the newer and sturdier construction to 5kg only (including adapter plate + bag). So not much room for luggage within the limits.
Martin_R is offline   Reply With Quote
Old 09-25-2009, 09:04 PM   #6 (permalink)
WardenRoss's Avatar
Not uncommon with the Sprint's also....
http://www.triumphrat.net/sprint-for...frame-fix.html
Warden Ross
Age Quod Agis
'06 Sprint ST
WardenRoss is offline   Reply With Quote
Old 09-29-2009, 01:14 PM   #7 (permalink)
SnuffBox10's Avatar
work hardening
It doubt it was the load that broke it. The sub-frame is aluminum and it will will work harden when it's flexed repeatidly. I bet what happened is that the assembly was vibrating and flexing that section of the frame until it got hard and cracked.
Before you go out and buy a new/used subframe, see if you can find a welding shop to fix it for you. Proabbaly cost a lot less.
Maybe they can whip up some sort of support for the box to keep it from happening again. Good luck
"When your racing your living, everything else is just waiting" -Steve McQueen
SnuffBox10 is offline   Reply With Quote
Old 09-29-2009, 02:50 PM   #8 (permalink)
yes mate new sub frame £350.00 got it welded for £30.00 and he did a very good job you would not have known any thing had happened
Old 09-30-2009, 04:09 PM   #9 (permalink)
wiayeman's Avatar
Are you putting it back on?
Old 09-30-2009, 04:24 PM   #10 (permalink)
no chance
I am an idiot (SW Motech top rack) chamade Sprint Forum 11 02-27-2009 10:19 AM
For those w/ the SW Motech rack.. txsprint Sprint Forum 3 10-15-2008 12:00 PM
SW Motech Alu Rack part problem deetyork Sprint Forum 7 01-24-2008 04:08 PM
SW-Motech Alu Rack - anyone have one? crudmop Speed Triple Forum 18 10-21-2007 08:26 PM
SW-Motech Top Rack RATLanta Sprint Forum 16 08-31-2006 08:52 AM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
