Originally Posted by toonyank
Has anyone ever experienced chain tension slip?
With the single sided swing arm I've adjusted the chain tension twice in 2 weeks and even though I've torqued the clamp bolt to the recommended 55Nm it just keeps loosing tension.
Has anyone experienced this kind of slip?
Not with my Speed Triple, Sprint, or my Ducati 748 with a similar adjustment setup.
When you say "it keeps loosing (sic) tension", do you mean the clamp bolt is backing off, and then the adjustment slips; or do you mean the adjustment slips while the clamp bolt stays torqued?
If the former, try blue Loctite. If the latter... no real suggestions. You'll probably have to take the hub apart and find out what's wrong.
KeS
