Run/Brake/Turn Conversion Kit - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports Ontario TourismSportbikeTrackGear
Old 09-21-2009, 02:11 AM   #1 (permalink)
Favourite Bike: 07 Triumph 1050 Speed Tip
Hi,
I bought a used/new 07 s3 last month with only 900 miles on it. Everything on it is still factory except the guy I bought it from removed the rear turn signals, and the giant rear plastic tail section. He tucked the license plate up underneath with a custom LED break/tail light. Long story short he was unable to find the turn signals so I don't have any rear turn signals.
I was wondering if anyone could suggest, or new of any run/brake/turn signal conversion kits that will work for my motorcycle so I can hook up turn signals to the existing LED brake/tail lights?
I have done a little research but have had no luck finding anything that looks like it will match up, or work with an 07 s3.
Thanks.
slowly_it_fades is offline   Reply With Quote
Old 09-21-2009, 04:03 AM   #2 (permalink)
Favourite Bike: Triumph speed triple
yes check out the intergrated tailights. I have a clearalternatives unit and it seems to work very good, it has the taillight,brake,turn signals built into the led board. its a direct fit for about 100 bucks unless you can find something on ebay. wiring is cake, comes with diagram and 15-20min install. good luck. just search for clearalternatives and you will find their site.
gaskinator5000 is offline   Reply With Quote
Turn Signal/Running Light Conversion Brooksie Twins Talk 11 10-23-2010 11:13 AM
signal conversion to brake lights? Thruxcapacitor Club Cafe' 6 06-23-2009 10:43 AM
Radial Brake Conversion cafetbird Maintenance & Workshop Talk 7 05-01-2008 05:31 PM
GSXR 1000 front brake conversion BulldogHooligan Speed Triple Forum 2 04-11-2007 01:30 PM
T100 TAIL LIGHT & TURN SIGNAL CONVERSION Brooksie Twins Talk 2 10-24-2005 07:34 PM
