Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 06-20-2005   #1 (permalink)
I unbolted the left side bolt, where the hose from the radiator goes to the engine. And the coolant came out. But is that all? Is there some other bolt i need to remove to drain everything? I want to do a coolant flush and put new coolant in there.
Also, i removed my left headlight, and the housing melted!! Anyone have problems with this?
Old 06-20-2005   #2 (permalink)
nyburner's Avatar
i completely flushed mine when i bought her, due to neglect and a rusted water pump impeller.
After draining the left side engine block drain plug, undo the the hose clamp on the left side of the radiator and drain. After it's empty, run a garden hose into the top radiator filler cover [it should have already been undone to drain all the coolant] until the water comes out clear. Obviously, do this outdoors or somewhere w/ a water drain in the ground. Put everything back and fill her up. Shake the bike as you fill to get the air bubbles out. Run for a minute or two, cool down, and check the level. Your gonna have to do this a couple times to get the additional air bubbles out [there's alot]. Fill the resevoir and your done.
Consider getting a triumph service or Haynes manual via ebay, it explains this and many other processes w/ pictures.
nyburner is offline   Reply With Quote
Old 06-20-2005   #3 (permalink)
nyburner's Avatar
fyi, the "recommended" procedures in the manuals i mentioned also include running the engine w/ coolant system cleaner, and then w/ only water once or twice before refilling w/ coolant, but that seems overkill to me.
Old 06-22-2005   #4 (permalink)
So, i should take a hose and put water into the radiator? I thought this would damage the bike?
Thanks for the advice, ill have to hose her down tonight.
Old 06-23-2005   #5 (permalink)
Favorite Bike: '01 Speed Triple
I've posted this before, but I recommend trying Evans waterless coolant. It has a higher boiling point 350F, and won't corrode your system. It's also good for years without changing. I haven't spewed coolant after a hot run since I put it in last fall.Click here
I forgot to add. You should pull off the bottom hose where it connects to the water pump, and a lot of old coolant will come out. The Evans NPG+ is what I'm using.
[ This message was edited by: Speed3 on 2005-06-23 05:41 ]
Speed3 is online now   Reply With Quote
Global meltdown ? Tbirdnz Biker Hang-Out 24 01-23-2008 03:17 AM
Draining The Tank Bonnebret Twins Technical Talk 6 09-11-2007 11:59 AM
radiator draining wookie Speed Triple Forum 23 04-30-2007 04:47 PM
t120 piston meltdown mattyg Classic, Vintage & Veteran 17 09-02-2005 01:46 AM
Draining the tank offroad55 Tiger Workshop 2 04-17-2005 08:08 PM
