2008 ecu - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!SportbikeTrackGearNew Bonneville
Old 09-19-2009, 11:19 AM   #1 (permalink)
2008 ecu
Will the ecu from a 2008 speed triple work on a 2006 speed triple?
What all would be required?
With the mapping that would be on the 08 ecu, would that change the 06 engine to be the same as an 08?
I have seen a couple of used 08 ecu's for sale, and was wondering if this would update my 06.
thanks
brett666 is offline   Reply With Quote
Old 09-19-2009, 11:37 AM   #2 (permalink)
Favourite Bike: 09 Speed Triple
Dan GSR's Avatar
i dont think that would work
why would you want to anyway?
09 Matte Black Speed Triple
MIVV GP carbon exhaust, grip puppies, tech spec tank pad, daytona brake light, brake light modulator, kisan headlight modulator, hella super tones.
Dan GSR is offline   Reply With Quote
Old 09-19-2009, 12:49 PM   #3 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
No.
At least the newer model's crankshaft position sensor + rotor as the newer has more teeth. I am also not quite sure the older gauge cluster is compatible with the newer ECU.
Why would you want to change your bike to the later and more emission restricted form?
The newer ECU does not unleash any major extra HP. You are much better off with the v1 Keihin ECU + TuneBoy. The first generation ECU is much easier to tune with TuneBoy than the newer one. Also many more downloadable tunes available for v1 ECU.
Martin_R is online now   Reply With Quote
Old 09-19-2009, 02:03 PM   #4 (permalink)
I read that the new ecu allowed easier starting, better fuel mileage,
smother acceleration, and higher horsepower.
Are you saying that the tuneboy can do the same?
Old 09-19-2009, 02:11 PM   #5 (permalink)
Favourite Bike: 2007 Green Speed Triple
Other Motorcycle: Honda CR450R
My dealership fried the ECU on my 2007 when uploading the TORS map. They didn't have another on hand so they took one out of a 2008 on the dealership floor, installed it in my bike and uploaded the map. 9000 miles later, everything works great.
mvoutour is offline   Reply With Quote
Old 09-19-2009, 02:31 PM   #6 (permalink)
Favourite Bike: Speed Triple 1050
matula's Avatar
Reader's Digest
Reader's Digest can tell anything. So can tell this internet. New isn't better. That fuel mileage might be a little better... and one thing. In 06 is even totally different main pin connector model in the ECU/ECM-box so 06 and 09 are NOT straight compatible. So Martin R remembers right. Once again.
I miss that older model with it's smooth power delivery. This new model feels in stock all the time like having a little lean fuel delivery. So I understand these Tuneboy-buyers...
matula is offline   Reply With Quote
Old 09-19-2009, 02:56 PM   #7 (permalink)
Martin_R's Avatar
Late model 07 bikes have the v2 Keihin ECU already, that explains why it was a straight swap for you and only the ECU program needed changing. This does not apply to v1 Keihin (05 to early 07) bikes.
Old 09-19-2009, 03:03 PM   #8 (permalink)
Martin_R's Avatar
That is true, but I would not worry about it too much.
better fuel mileage, smother acceleration, and higher horsepower.
These are more tuning issues than actual ECU hardware related.
Yes, a TuneBoy tuned 05 bike will have noticeably more grunt than a stock 09 bike.
In stock form I would say the 09 is weaker in low revs than a 05.
Old 09-19-2009, 06:19 PM   #9 (permalink)
Other Motorcycle: Ducati Street Fighter
I agree. When I got my 2009 I swear it felt significantly less powerful. I was weirded out at first. I attributed it to the fact it was new, needed to be broken in. Well thousands of miles later it still didn't feel as grunty as my previous S3. Then I remapped it, did some exhaust/pre-cat, header stuff to it and it's right back to where it should be.....a beast!
29138 is offline   Reply With Quote
Old 09-19-2009, 07:33 PM   #10 (permalink)
Will using the Tuneboy fix the starting problem with the 06?
You know, the long cranking time and stumbling until it warms up?
Thanks
Ibr 2008 mnhoulden Ride / Trip Reports 5 11-02-2008 11:14 PM
What makes the 2008 thrux a 2008? CaptainCafe' Club Cafe' 6 05-30-2008 04:03 PM
2008 Dragon Raid May 8-11 2008 triumph_955_st Rides & Events 6 04-13-2008 09:15 PM
2008 and pre-2008 gas tanks PhxTrump Twins Talk 9 03-20-2008 02:20 AM
2008 St scott1050 Sprint Forum 39 02-14-2008 03:12 AM
