Need quick advice re: oil leak
This is in regards to an 07 model. I have a manual on the way, but it may be another week before it arrives so anyone with advice or the correct procedure to fix this is appreciated.
Here's the issue: On the right side of the engine there is a round plug(?) about 3 inches or so round that has what looks to be a 17mm nut in the center of it. It is located right in the center of where the crankshaft would be. This "seal" has recently begun to leak oil and its getting worse quickly.
Does anyone know if this is a repair that simply involves removing the nut? I'm afraid that there may be something behind it like uhm, a flywheel....or?
Thanks!
