Springfield ArmoryShopTriumph.comBikeBanditSportbikeTrackGearTrident-Exhausts.comRacerPartsWholesaleMotorcycle.comMotorcycle.com Classifieds!
Old 06-18-2005   #1 (permalink)
TM
How do I turn off the headlights on my S3-05? There must be some "secret" way to do this (press horn, brake, set-button @ same time for 4 sec or something similar). Anyone?
TM is offline   Reply With Quote
Old 06-18-2005   #2 (permalink)
all new bikes in uk at least are lights on all the time. i think its a good thing as it make you much more visible
officer you try and keep it on two wheels
Celt is offline   Reply With Quote
Old 06-18-2005   #3 (permalink)
TM
I agree, but there are certain times when I temporary want to turn off the headlights (track-days, photosessions etc).
So, does anyone know how to turn off the headlights on the S3 (other than remove fuse/lamps, cut cables)?
[ This message was edited by: TM on 2005-06-18 19:15 ]
Old 06-18-2005   #4 (permalink)
no sorry cant help but there must be a way. maybe just dis-connect is only way.
i wander if those black covers you get for fog lamps on cars would work
Old 06-18-2005   #5 (permalink)
TM
I suspect that if you cover the headlights (without turning them off) you could run the risk of overheating them.
Old 06-18-2005   #6 (permalink)
I have been told that Triumph no longer even has switch gear for making the lights capable of being turned off. There is no "Magic Button Combination." If you want to turn them off for a Track Day then just pull the fuse. Simple, reversible, and takes seconds.
If you have another reason for wanting your lights off then you will have to do a little electrical work and install a switch somewhere. It is possible to find switch gear that has an on/off light switch that matches the factory Triumph switch gear- however you will have to take out a loan on important parts of your anatomy to afford them. Worse, the Triumph wiring harness doesn't support it so you will have to become a wiring technician anyway.
Unless you're trying to break out of a Nazi prison camp just leave your lights on.
crashmasterd is offline   Reply With Quote
Old 06-18-2005   #7 (permalink)
Id prefer if the lights didnt come on until the engine was started. To save all the possible electricity for the starter. Most bikes ive owned were like this. Turn on the key and the lights stay off until after the engine is started then they come on.
Hotmailrules is offline   Reply With Quote
Old 06-18-2005   #8 (permalink)
TM
On 2005-06-18 20:32, crashmasterd wrote:
[snip]
Forgot about that one :lollol:
Old 06-19-2005   #9 (permalink)
Check it out: When you press the starter button your bike automatically turns off the lights. The last four bikes I've owned have done this. When you let off on the starter button the lights come back on.
The 3 to 5 seconds your lights are on before you hit the starter isn't going to drain enough from your battery to cause any problems. In any case, with a battery in good condition it shouldn't be an issue. Leave your light on for five minutes and your bike should still start.
The only bikes I've ever owned that did this had kickstarters and ignitions that didn't require a battery. The reason behind this is that the headlight drains too much energy from the ignition/charging system for the bike to start if there is a dead battery. Even if the bike does have an electric starter.
[ This message was edited by: crashmasterd on 2005-06-18 23:18 ]
Old 06-19-2005   #10 (permalink)
ES3
That is not a good solution, because the same fuse(8) is used for the start engine. For my track day I simply removed the lamps, I didn't find a easier solution.
No more Triumph
ES3 is offline   Reply With Quote
Right turn vs Left turn Kramocker Twins Technical Talk 14 11-18-2007 12:21 PM
Headlights SpeedBob Speed Triple Forum 10 07-12-2007 12:29 AM
ST Headlights TXRyder Speed Triple Forum 0 01-21-2006 01:43 AM
remounting clocks and headlights to turn with forks? lromoda Speed Triple Forum 4 01-04-2006 08:20 PM
S4 headlights Catenaccio Modifications & Workshop Talk 4 06-27-2005 03:16 PM
