On 2005-06-13 18:42, crashmasterd wrote:
As I recall Sir Loin was dealing with Techlusion to help develop their fuel modification system for the new 05 Speed Triple. It's not as sophisticated as Tuneboy or PowerCommander, but it should give you some tweaking options. Once I hear how it's working I may just give it a try. Cheaper than PowerCommander or Tuneboy, and doesn't require a PC. It's developed by the same guy that developed the PowerCommander
Click hear for Techlusion
The new Fuel Injection is built by Kiehn, if I'm not mistaken. Are any other motorcycles using this FI system? And if so, don't you suppose there are some serious engine tweakers out there that understand it?
You are right. I've sent them wiring photos and a diagram of the 02 sensor, and I should have the 02 bypass in hand this week. They had a production run just recently. They already sent me the TFI box which consists of 4 potentiometers to adjust idle, cruise, full throttle, and high rpm fuelling.
I am going back to using the TFI because of the success I had when modifying a Suzuki TLS. The TFI box made a huge difference in the bikes performance.
The box is very easy to dial in, and can be adjusted during test riding, or dyno'd to squeeze the very last bit of performance out of it.
Once I get the TFI installed and dialled in on the Triple, I'll make a detailed post on settings, results etc.
