So you start it cold, it starts fine, idles fine until it reaches 183 deg F, then starts bumpin and humpin? Then you rev it and it runs fine after you hit 2200 rpm?
What happens if you just let it idle?
How do you know it's running on 2 cylinders?
What happens if you leave it idling up to high temp when the fan turns on?
