Originally Posted by youngatheart
Just wondering if you have researched the effects on handling resulting from this as this bike handles drastically better than my 01 did?
Also would like to know where you got the wheel and if it matches somewhat and if it was a custom......Thanks
I'm getting a set of BST carbon fibre wheels in the seven-spoke design, such as that developed for the Ducati Hypermotard. BST has develop a solution for the Speedie, and while my prefernce is for a stock 5.75 inch wheel, I may only be able to get a 6.
http://www.blackstonetek.com/products.php (see the set profiled at the top of this page)
I'm building a project road bike that is both a mix of asthetic and function for blasting the twistie back roads of AR. The wheels are the next steps in helping to enhance the agility and the asthetic - the rear alone drops about 4 kg (8.9 lbs) of unsprung, rotational mass.
All other things being the same, a larger rear wheel (of equal mass)would reduce agility (which is the exact opposite of my intent), while increasing the contact patch; however, tire sizes can be extremely varible from one manufacturer to another and so one can have a small 190 or a larger 180 and there would not always be a 10 mm difference betwen the two.
All said, I'm going for a 5.75 if they do/will make it; however, if not, I'm going to fit the 6 incher. I think the benefits of the super-light wheels will outweigh any (and likely minor) ill affects of a 190 tire on agility. I will probably have increased agility and a larger contact patch with the 6 inch BST wheel, even though I'd prefer to have even more agility and the same contact patch.
The only reason I am looking for a 190 tire is that this is the optimal tire size for a 6 inch rim -- you want to preserve the profile of the tire. A 190 on a 5.75 inch wheel pinches the beads closer to the centerline of the wheel, increasing the roundness of the profile and reducing the contact patch; a 180 on a 6 inch rim would have the beads further out from what is optimal, creating a flatter or even a convex contact patch when the bike is upright, resulting in poor turn-in characteristics.
My original question still stands - has anybody used spacers to increase the clearance of the pipe, and what are the results? If not, I'm interested on an informed opinion about potential stress to the header pipes at engine's exhaust ports.
