Need help to remove ignition from top clamp - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-26-2009, 11:41 PM   #1 (permalink)
Favourite Bike: Mine
crat996's Avatar
Other Motorcycle: '99 Ducati 996S
I am replacing lower triple clamp and while i had the bike apart i wanted to get the top clamp powder coated. Can anyone explain how to remove the ignition switch from the top clamp?
thanks in advance.
'99 Ducati 996S
'07 Speed Triple
crat996 is offline   Reply With Quote
Old 07-27-2009, 12:19 AM   #2 (permalink)
DEcosse's Avatar
The bolts are shear bolts - the heads snap off (deliberately) when installed - anti-theft measure.
You'll need to drill them out most likely.
You can get similar replacements from Triumph, but probably easier to just replace with std socket cap screws.
T'Rat.net BOTM November 2009
Old 07-27-2009, 02:04 AM   #3 (permalink)
Favourite Bike: 2000 Triumph Daytona
t955i2001's Avatar
Other Motorcycle: 2007 zx14 inercooledturbo
Extra Motorcycle: 2009 Ducati 848
I have been able to take a small flat chisel and hit the edge of the bolts counter clockwise and brake them loose and then turn them out with a pair of pliers.
t955i2001 is offline   Reply With Quote
Old 07-27-2009, 06:17 PM   #4 (permalink)
I just grabbed the heads w/ a pair of pliers and was able to back them out.
From the top of my desk to the bottom of your trashcan
superduty is offline   Reply With Quote
Old 07-27-2009, 09:55 PM   #5 (permalink)
crat996's Avatar
I used a dremel and cut a slot in them and they came out like a champ.
'99 Ducati 996S
'07 Speed Triple
Old 07-28-2009, 12:18 AM   #6 (permalink)
Favourite Bike: Speedy!
Ditto
Deano
sss1200 is offline   Reply With Quote
Triple Clamp and ignition---Help posse Speed Triple Forum 9 04-24-2009 05:39 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 01:50 PM
How To Remove Upper Fork Clamp? Brooksie Daytona Deliberations 10 06-18-2006 01:29 PM
How do you remove marks from the triple clamp? Speed Triple Forum 5 09-15-2004 02:07 AM
How do I remove the ignition Maintenance & Workshop Talk 1 09-14-2004 10:04 AM
