On 2005-06-03 13:22, greenocktriple wrote:
I think disconnecting the wire does show something it shows your pressure switch is closed ,operated jammed or whatever.ie closed circuit!!!!it is only a single wire to it, all it does is short to earth via a resistor activating the warning light!
Well the above is just plain wrong. If you disconnect the wire and the light stays on you know that the faulty part is in the connecting wire/electronics and not the switch itself.
If the light goes out when you disconnect the wire, it tells you nothing about the operational state of the switch, it just tells you that the switch is on. And the switch might be on for a good reason.
That aside, I seem to have the '05 S3 switch bug also or water in the electrics. The light came on a while after I washed my bike. It seems that the light comes on at around 2000 revs/min or above.
If there really was a problem with the oil circulation shouldn't the light be on at lower revs and go out at higher when the pressure increases? Mine seems to work backwards and comes on at higher revs.
Is something really wrong with the engine? Oil level is fine and the engine is running smoothly with no noises or such (although I have not really ridden the bike after this just to be safe).
Edit. How did the problem resolve for you guys who had the light on? Was it just a faulty switch?
[ This message was edited by: Martin_R on 2005-06-06 15:08 ]
