Had the same issue with my Triumph CF High mount. Ended up cutting out a piece of a coke can (actually used a sprite can, but same difference), then cut it to fit around the male end of the adapter pipe that came with the exhaust, gooped it up with some High Temp RTV silcone and WA LA......no more leak.
I like the idea of a different clamp though. The stock clamp really does not seem to clamp all the way down as it should............hence the use of the piece of coke can to add some width to the pipe to help the clamp work better.......
I think the High Temp RTV and a new clamp would be the best way to go. I ended up using the piece of aluminum can because no matter how tight I got the clamp the pipe would still move back and forth (as well as leak) and it drove me nuts................Probably gonna go with the new clamp idea the next time I take it apart...........
Live and learn - thats what I love about this forum.........
Good Luck.............
Ken
