Old 05-28-2005   #1 (permalink)
What to do? I have driven about 1000km. I changed the oil (Mobil 1 Racing 4T 15W/50) and filter in 800km as instructed and have no problems except for the warning light. There are no additional engine noises and it runs fine. I’m beginning to thinks it’s a problem with the warning light switch and not the engine. How can I be sure of this? I probably should just call to the dealer and let the warranty take care of it, but I’m in a hurry because I need the bike for an upcoming track day very soon.
*.m
Xibalban is offline   Reply With Quote
Old 05-28-2005   #2 (permalink)
TM
I assume that the Mobil 1 Racing 4T 15W/50 is a fully-synthetic oil and the oil pressure warning lights constantly when you are driving?
Call the dealer, you'll probably loose your warranty if you drive with the oil pressure warning light on and something breaks.
TM is offline   Reply With Quote
Old 05-28-2005   #3 (permalink)
Did you follow the instructions in the manual to the letter? and forgot to put in the drain plug :-D JK. The fact that the light didnt come on before the oil was changed worries me. I doubt the low oil pressure sensor would go bad right after an oil change. If the oil level is correct id be thinking about flatbedding it to the dealer if I saw the light anymore.
Hotmailrules is offline   Reply With Quote
Glowing Oil Warning Light - TBS robnobrakes Hinckley Classic Triples 1 12-29-2007 09:06 AM
Oil warning light stays on trophy_cup Trophy 4 10-06-2006 08:11 PM
Oil Presure Warning Light HorseWhisperer Modifications & Workshop Talk 2 06-05-2006 11:28 PM
oil pressure warning on start up punisher Triumph SuperSports 4 09-30-2005 01:57 AM
flashing oil pressure warning light Sprint Forum 2 09-12-2004 08:59 AM
