Springfield ArmoryShopTriumph.comBikeBanditSportbikeTrackGearTrident-Exhausts.comRacerPartsWholesaleMotorcycle.comMotorcycle.com Classifieds!
Old 05-27-2005   #1 (permalink)
Hi S3 fans,
I just bought a '05 S3 a week ago. I'm still breaking in the engine, but I must admit it already feels marvelous. I previously rode a VTR 1000 F, and I thought I would miss the torqy feel, but I don't.
The brakes are also muuuch better, but then I've noticed that when trying to brake a little bit hard, I experience some rebounds on the front fork that I think they could be solved adjusting a little bit the fork settings.
Any idea of what should I do in order to get a more stable braking? I've noticed that using the rear brake helps keeping the bike more stable, but I'd like to be able to use just the front one when riding hard. The engine brake good enough for not needing rear brake, just like most of the twins.
Thanks in advance for your advice!
drmuela is offline   Reply With Quote
Old 05-27-2005   #2 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Take a look at the manual and try out the recommended 'Hard' suspension settings (remember to adjust the rear to match the front) before inventing your own combination. I feel the recommendations are quite good and balanced.
This should cure the rocking horse behaviour when you are braking if that is what you were referring to with your "rebounds" experience.
Martin_R is offline   Reply With Quote
00 RS Front fork leaking ckassen Modifications & Workshop Talk 8 07-18-2007 10:19 AM
Ohlins R&T Front Fork Help SIN138 Speed Triple Forum 2 07-13-2006 04:20 PM
Bonneville front/rear brake lever adjustments??? mecscc Twins Talk 9 04-12-2006 08:42 AM
Front fork Sheilds Berkgeorge Twins Talk 8 04-07-2006 10:16 PM
Front Fork alignment tealetm T3 Sport / Touring Forum 1 02-27-2006 08:25 PM
