2006 Rough idle after warm up and sometimes cuts off. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 04-25-2009, 01:45 PM Thread Starter
Main Motorcycle: .
Hello, My 2006 runs great when I first get on and ride for 20 min or so. Then I noticed at a light that the idle was becoming eradict. I had to give it lots of gas and release the clutch slowly to get out of the way. When I get up to speed things seem to smooth out but its when I am stopped when things start to go wrong. Its shut off on me at lights more than once. NOT GOOD. Any ideas?
schaney is offline
post #2 of 12 (permalink) Old 04-25-2009, 02:00 PM
Main Motorcycle: Speed Triple
Do you have a check engine light?
Sounds like one of your sensors is bad. Could be MAP, TPS, or O2. Best to check the codes.
TripleZ is offline
post #3 of 12 (permalink) Old 04-25-2009, 02:31 PM Thread Starter
Main Motorcycle: .
No check engine light. I just let it warm up again and it sounds good until it gets warm. At 6 bars the fan cuts on but after about 5 fan cycles the engine starts to miss. Like its running on 2 cylinders or something. It corrects and then does it over again. When I give it gas it hesitates and then runs good (2000 rpm). When I release the throttle it idle eradically.
schaney is offline
post #4 of 12 (permalink) Old 04-25-2009, 02:33 PM Thread Starter
Main Motorcycle: .
Is there another way to check the codes other than taking the bike to the dealer?
schaney is offline
post #5 of 12 (permalink) Old 04-25-2009, 03:26 PM
Main Motorcycle: 06 Speed Triple
Joemomma's Avatar
Other Motorcycle: 99 SV 650
Extra Motorcycle: 03 WR250F
U can ck codes with a tuneboy...when was the last time you changed plugs? Synced throttle bodies? Do you have a "whoosh" sound when you open the gas cap?
insert clever saying here...
Joemomma is offline
post #6 of 12 (permalink) Old 04-25-2009, 05:15 PM Thread Starter
Main Motorcycle: .
Tune Boy.. Well I guess its time I got one of those. My bikes got 14k miles on her and I haven't changed the plugs yet. So far I've taken off the cover for the airbox but I don't have a clue on what to do next. I see the hoses that need to be taken off and the two screws in the back but it still doesn't budge. I'm not liking what I'm seeing as I look down the intake though.. Lots of black crud caked up around my valves. Is this normal? Can you tell me how to remove the airbox?
schaney is offline
post #7 of 12 (permalink) Old 04-25-2009, 06:22 PM Thread Starter
Main Motorcycle: .
I know this is old news for some of you. I found an old post about how to remove the airbox to get to the spark plugs.. And yeah, its easier than it looks. I had to use an air-compressor to blow out the built up water on top of the plugs it looks like its been like that for a while, rusty and all. The plugs look burnt but what bothers me is that I don't see shiney metal when I look through the little spark plug opening I see built up crud in my cylinder. I've got an aftermarket low-boy exhaust with the 3-in-1 tune. Does this mean that I'm running way too rich?
schaney is offline
post #8 of 12 (permalink) Old 04-26-2009, 07:26 AM Thread Starter
Main Motorcycle: .
Thanks Bohdan, now I can clean it out before I put everything back together. Now I'm thinking of putting in the same old spark plugs while I clean it out (the first go around anyway) before I put in the new NGK Iridium spark plugs.
schaney is offline
post #9 of 12 (permalink) Old 04-26-2009, 10:51 AM
Main Motorcycle: 2006 gsxr1000
Other Motorcycle: 2008 Speed triple
Extra Motorcycle: 2008 Ktm Smr450(plated)
hey guys you can check your codes with any scan tool for a obd2 vehicle. i did this already when i was diagnosing a issue with my bike. there is an obd port beside the battery
blastap is offline
post #10 of 12 (permalink) Old 04-29-2009, 09:24 PM
Main Motorcycle: '06 Speed Triple
Why not just go ahead and throw in fresh plugs?
S3's good for me!
ChattyS3 is offline
Cuts out when warm Herbs Air Cooled Twins Technical Talk 12 11-23-2008 11:20 PM
rough idle jonno1953 Air Cooled Twins Technical Talk 10 11-14-2007 02:56 PM
Rough idle htown16 Classic, Vintage & Veteran 7 07-25-2006 08:46 PM
Rough Idle OlyKen Sprint Forum 4 07-12-2004 04:03 AM
Warm t-bird running rough Maintenance & Workshop Talk 10 05-04-2004 10:34 AM
