higher bars
Hi,
I did two things to my '07 speedie to raise the bars. First, I installed a set of '02 Honda 919 bars. These are a little narrower and at least two inches higher/back. You can install these without new cables, etc., although the front brake line may not stay in the front fender clips anymore. I still needed more, so I made homemade bar risers out of a pair of 3/8 drive 1" sockets under the mounts for the bars, and bought 1" longer bolts from McMaster/Carr. This did require a new brake line, but everything else (clutch cable, wiring) still worked without modification.
Either one of these mods may work for you.
