to reset the clock.......select clock display and press BOTH "scroll" and "set" buttons together.After a short time,the clocks hour display will start to flash.
To reset the hour display ensure that the hour display is still flashing and press the "scroll" button to change the setting.Each press will change the setting by 1 digit.
When the correct hour display is shown, press the "set" button. The minutes display will start to flash, Adjust using same method.
Once the hours and mins are correctly set, press the "set"button to confirm the setting.The display will cease to flash.
