Need Slider Recommendations for '09 SP3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-03-2009, 03:22 PM   #1 (permalink)
All
I have seen tons of threads out there on sliders and I'm trying to figure out :
1) Which frame sliders are the best and have you used brackets to move them away from the knees? i.e. GSGs
2) Which engine protectors are the best?
3) Handle Bar Sliders?
4) Axles?
Thanks!
g-smitty
gsmitty is offline   Reply With Quote
Old 04-03-2009, 08:25 PM   #2 (permalink)
Favourite Bike: Triumph Daytona 1200
vfdaytona1200's Avatar
GSG forward offset frame sliders are great for tall riders and are out of the way of your knees. They also provide great protection to your Speedy. Go gsg for all the protection you need they make a great product....British Customs sells them
Who has a stretched Triumph? I do!
vfdaytona1200 is offline   Reply With Quote
Old 04-04-2009, 10:14 AM   #3 (permalink)
Scrambler007's Avatar
These Rizoma look classy and are pretty cheap at 95$ a pair...Ill probably start with those...
Rizoma sliders
Scrambler007 is offline   Reply With Quote
Old 04-07-2009, 07:22 AM   #4 (permalink)
Newbie
DPM engine protectors
I have the engine protectors from DPM on my bike and like them a lot, bot esthetically as well as knee freedom.
http://www.deprettomoto.com/articoli..._modello=4/145
stadsfiets is offline   Reply With Quote
Old 04-07-2009, 07:39 AM   #5 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Are you sure you want a 200kg bike to slide down the street on a slider that has a lever attached to it?
Looks like the frame / head lug will snap like a twig if proper pressure is put on the slider.
Martin_R is online now   Reply With Quote
Old 04-07-2009, 07:54 AM   #6 (permalink)
I'm sure it's more solid without a lever, but I doupt Rizoma would produce subpar products. Ill probably add some lower motor protection after so I'm pretty sure it would save plenty of dammage...I also hate having something right in front of my legs (I'm 6'1")...so I think these are better then bare frame if I drop it, although I hope the sliders will never be used!
Old 04-07-2009, 11:38 AM   #7 (permalink)
R&G`s are pretty good.
My right knee sometimes touches the right hand slider if Im braking hard, otherwise I wouldent know they are there.
They also do some lower engine protection but I dont have this fitted (yet).
What I would like to see for our engines is some Covers to put on them like the GB Racing ones seen on the Street/Daytona.
Reppyboyo is offline   Reply With Quote
Old 04-07-2009, 11:54 AM   #8 (permalink)
There's quite a few covers for the Speed..I dont know how much more you need? Maybe a tank is what you need?
My bike is fully insured, so I don't want to spend 1000$ on sliders either...I want to avoid some damage in a low speed crash but if I have a serious accident the bike will be the least of my preoccupations...so Im going for a minimal setup that still offers more protection then a bare frame...:
Old 04-07-2009, 12:28 PM   #9 (permalink)
Favourite Bike: 2007 Speed Triple
bobmcduff's Avatar
Other Motorcycle: 1986 Honda XL250R - SOLD!
I have the R&G engine guards on my 07.... havent tested them though (there is a thread around here for someone who has though).
bobmcduff is offline   Reply With Quote
Old 04-07-2009, 12:57 PM   #10 (permalink)
Martin_R's Avatar
I have a similar philosophy, albeit I have taken it a bit further. If I ever get into a crash severe enough to crack the handlebars or bend them far enough for the frame to touch down, then the bumpstops on the frame have already sheared -> the frame is a writeoff anyway. Hence I go with no sliders.
Engine cases and radiator etc I can replace easy enough, so I see no reason to go too far to protect these.
No-cut frame slider kit tri955i Daytona Deliberations 3 02-10-2009 11:33 PM
Left slider v right slider... Max_NYC Speed Triple Forum 18 08-14-2007 01:31 AM
slider install sodapop Sprint Forum 1 06-29-2007 10:36 PM
Frame Slider Recommendations cshell Speed Triple Forum 17 09-27-2006 10:14 PM
Slider help Triple_Rider Speed Triple Forum 0 09-17-2006 11:10 AM
