Old 05-13-2005   #1 (permalink)
My local Triumph dealer has just called me to advise me that my 2002 striple won't start due the starter motor sprag is no good..He wants £400/$750 to fix it.
This sounds a lot of money for me at the moment, so........
Anyone know if this is an easy job to do myself?
Can't be that difficult can it?
Thanks,
Rod
I was planning on saying everything I had to say here in one sitting but have since realized that by sitting and saying with everything I was planning is merely half good at least as me sitting here screaming and saying nothing. so there...
RODST3 is offline   Reply With Quote
Old 05-13-2005   #2 (permalink)
[ This message was edited by: Captain_Rat on 2005-05-13 15:51 ]
Captain_Rat is offline   Reply With Quote
Old 05-14-2005   #3 (permalink)
Eh?
Old 05-14-2005   #4 (permalink)
Eh?
Old 05-14-2005   #5 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
I thought the sprag clutch problem had been fixed with the later model engines - what is the symptom? If it's the sprag clutch the starter will just spin, not grabbing the crank.
It's a big job if it really is bad, engine out disassembly I believe.
GSXR 1000 Front End Swap
Old 05-14-2005   #6 (permalink)
DEcosse's Avatar
Old 05-14-2005   #7 (permalink)
The starter motor spins for about 3-4secs then dies away but the engine doesn't catch.
Old 05-14-2005   #8 (permalink)
Old 05-15-2005   #9 (permalink)
greenocktriple's Avatar
Is it turning the engine over?if not it sounds like its an engine out job to split the engine for access,worth taking apart yourself,labour alone i read was about£600.Hope thats not your prob worth contacting triumph,because this was meant to be remedied by now.good luck. :???:
BETTER A DAY AS A LION THAN A LIFETIME AS A SHEEP.
greenocktriple is offline   Reply With Quote
Old 05-15-2005   #10 (permalink)
Starter Sprag Job -- Parts maxpower Hinckley Classic Triples 25 01-06-2007 04:41 PM
Starter or sprag clutch problem? parrycm Hinckley Classic Triples 8 09-23-2005 11:18 PM
New Starter sprag clutch Trophy 3 05-10-2005 07:16 AM
Starter Sprag Clutch on T-Bird SWare Modifications & Workshop Talk 3 02-28-2005 02:32 PM
Starter Sprag Clutch replacement SWare Hinckley Classic Triples 0 02-28-2005 12:13 PM
