Motorcycle.com Classifieds!ShopTriumph.comRacerPartsWholesaleSportbikeTrackGearTrident-Exhausts.comBikeBanditMotorcycle.comSpringfield Armory
Old 05-11-2005   #1 (permalink)
I was thinking I needed 14mm diameter. Is this right?
Hotmailrules is offline   Reply With Quote
Old 05-11-2005   #2 (permalink)
Favorite Bike: '01 Speed Triple
14 mm sounds too small. What kind of stand are you getting? You can specify what model you have, and order the correct pin. Measure the ID and you'll have your pin size,
Speed3 is offline   Reply With Quote
Old 05-11-2005   #3 (permalink)
the exact size is 27,5 mm.
This size fits for all Triumph and for all Honda VFR RC36 and RC46.
Ephtriple is offline   Reply With Quote
Old 05-11-2005   #4 (permalink)
Which side is that? It's different depending on whether you lift it from the left or the right. The right side is larger.
mjw930 is offline   Reply With Quote
Old 05-11-2005   #5 (permalink)
left side then. So I can remove the tire. I dont need to lift from the right bacause you can remove the sprocket without a lift.
Old 05-11-2005   #6 (permalink)
the size I mentionned is for the left side.
Old 05-11-2005   #7 (permalink)
here a pic of mine...
[ This message was edited by: Ephtriple on 2005-05-11 14:01 ]
Pin strong enough for swingarm pivot stand? batistuta Speed Triple Forum 8 03-27-2007 09:32 AM
rear stand pin diameter ctrhenry Speed Triple Forum 14 12-18-2006 05:22 PM
swingarm stand size stmike Speed Triple Forum 2 05-26-2006 12:35 AM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 07:21 AM
what size pin do I need for swing arm stand? Hotmailrules Sprint Forum 1 05-11-2005 07:43 AM
