I have a 2001 S3 with about 8k miles and the Triumph aftermarket high carbon silencer and am experiencing a similar problem. The bike did not want to idle, without throttle input, and was difficult to pull from a standstill, without feathering the clutch. The local dealer loaded a different program for the fuel injection, which fixed the idle and off-the-line problem, but other problems still exist (or perhaps got worse). After the bike is warmed up (15-20 minutes) and at a partial throttle position, the bike caughs and sputters, as though the ignition is intermittently cutting out, or the fuel is being cut off (similar sensation to running out of gas). I don't know if this is a fuel problem (clogged gas filter?) an ignition problem (broken wire or problem with spark plug) or is simply running the wrong ignition software. Has anyone had any similar experience, and if so, how have you sorted the problem?
'09 Scrambler - matte khaki green
'06 Speed Triple - scorched yellow
'04 Bonneville T100 - Project '61 - sky blue and silver
'66 TR6SC Trophy Special - pacific blue and white
'07 BMW R1200RT - silver; '09 Vespa GTS 250 Super - black
